Rear Camber Correction (washers)
Old Feb 17, 2004 | 10:42 AM
ATrain3.0's Avatar
I've done a search and didn't find the specifics I was looking for. I have pro-kit springs with KYB-AGX on a 3.0. I noticed my rear tires were wearing on the inside. The fronts are fine. Which kind of makes sense because the front isn't as low. Anyway, can someone give me specific instructions on how to correct the rear camber with washers. I'm low on cash and want to save my tires.
Old Feb 17, 2004 | 10:56 AM
ATLcl98's Avatar
Atl/Mia reppin'
first things first, did you take your car in for an alignment? They might be able to get it within specs...
Old Feb 17, 2004 | 12:35 PM
DanMan1464's Avatar
Autobot
camber can't be aligned stock....they couldn't do mine....gotta buy a camber kit
Old Feb 17, 2004 | 12:41 PM
baka_t's Avatar
The movement has started
Took my car around 16 washers per side to get my camber corrected. Im dropped around 3"
Old Feb 17, 2004 | 01:08 PM
ib_jimmy's Avatar
no they can correct ur cambers without a camber kit if its slightly drop like the pro-kit....u said u notice wearing from the inside rear? usually its just the front....the back hardly wear from the inside unless u have a lot of weight in the trunk....also...usually with pro-kit u dont even need a camber kit.
Old Feb 17, 2004 | 01:10 PM
ib_jimmy's Avatar
I got neuspeed sport on my with kyb agx and no camber needed for the front....tires doesn't wear out from the inside at all...and i drive the hell out of my car....burn out and all....it wear even....my rear i put in like 3 washer each and corrected slightly cuz of my subs.
Old Feb 17, 2004 | 01:30 PM
ATrain3.0's Avatar
I did have the car aligned when I had the springs installed four months ago. By the way, I bought the springs and struts used, so I didn't think they would settle too much. so where exactly do the washers go?
Old Feb 17, 2004 | 01:38 PM
ib_jimmy's Avatar
there's 2 bolts holding the upper arm....the washer would be place behide the arm mount to push the upper arm control out making the top of the wheel further out.
Old Feb 17, 2004 | 02:58 PM
ATrain3.0's Avatar
thanks I'll give a try probably this weekend. I'll eventually get camber kits all around and go for a lower drop. My money's going toward tint and exhaust this week though.
james357
Feb 13, 2016 02:37 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
nanos
Nov 12, 2015 08:41 PM
thegipper
Oct 21, 2015 07:19 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
