really bad alignment problem after installing rotors?
ok guys, just got Brembo cross drilled slotted rotors installed and 18 inch Katana Tezza installed and new brake pad. after that take a test drive, and the car is HORRIBLY pull to the left... any ideas??? Thanks
forgot to tell you this part, i think this caused it. you know the 2 screws that hold the rotors ?? it was a PAIN in the azz to take that out, i could not unscrew it, use all kind of shit. What i did was take a srew driver and a hammer. I hammer it at an angle so it can unscrew, took about 15 mins for each rotors.... that must be it huh?
if you just installed the new wheels, it might be that. when i put my 18 inch in with new tires, the car pull to the right a lil, which didnt happened b4. i went for an alightment, and they said everything is centered, but the car still pull to the right. i read on the tirerack that some brand and model tires cause this behavior.
also, to remove the two screws in the rotor, you need an impact screw driver.
ok guys, did the alignment today, the same shit, still pulls to the left, could it be the tire? i have the kumho 712 225/40/18 on mine.. tires not balance?? please help it's getting annoying driving her when just wants to pull left.. I noticed that she pulled left less when i drive fast but about 20-50 it's pull really hard...
the guy said my right camber is .4 degree off , y just on the right??
thank you guys
thank you guys
VtecVsix: where did you buy the drilled slotted rotors from and how much did you pay for the front rear and the pads? Let me know cuz i'm planning on buying it this week. Thanks!
