real quick help
Old Feb 1, 2009 | 01:52 PM
QuentinRice's Avatar
real quick help
ok so I am taking my back seats out right now (im taking a break to ask this) and I took the 10mm bolt out and I see the 2 clips in the front but I still cannot seem to get them out. I searched, YES. But I still dont see anyone else with the trouble I am going through. Can anyone walk me through this really quick, Thanks
Gnate's Avatar
Custom User Title
Okay if you take all the bolts out you should be able to just lift the seat up and the clips should undo
I had that same problem, and was pissed when i realized how simple it was hah
Old Feb 1, 2009 | 01:59 PM
The only bolt for the bottom cusion is the 1 10mm bolt right?
Am i supposed to pull up REALLY hard or what, because many people were talking about screwing up their clips and Im definantly not trying to do that!
Old Feb 1, 2009 | 02:04 PM
Gnate's Avatar
Custom User Title
I there are 2 bolts for the bottom cushion if i remmeber correctly, one on the left near the seatbelt, and one on the right near the seatbelt... check there and let me know if i'm right...
actually i'll go look at my car now.
Old Feb 1, 2009 | 02:08 PM
YES! You were right, I found the 2nd bolt and it is out too..
im am trying to pull straight up on the cusion but it isnt wanting to come out? Do I push in or pull out on the clips, and is it safe to use alot of force, or are these clips fragile?
Gnate's Avatar
Custom User Title
Okay I went out and looked at my car, There was only one bolt for the bottom cushion and it was in the middleish area, but it looked to me like I was missing another bolt, so there should be two bolts in the middle area, you can find them at the base of the back rest cushion.
It turns out it was my back cushion that isn't even bolted in at all, that piece i can just lift up, the clips come out and the cushion comes right off. that's not too safe!
did you take out the seatbelts yet? Because you arent going to get it out without them removed... or at least pushed through the cushion so they are no longer connected to it.
Old Feb 1, 2009 | 02:12 PM
Ok, I reread this and some other searches and got both 10mm bolts out and i pushed the seatbelts through.
I can open the seat bottom up, pivoting on the clips. I CANNOT figure out how to get the clips loose. what did you do?
and thanks for the help!
Old Feb 1, 2009 | 02:41 PM
Gnate's Avatar
Custom User Title
I really don't know what else to tell you, just wriggle it around in different directions and positions I guess, my seat was fucked up, like i said there were bolts missing etc.
Try taking out the back cushion for better visibility?
Good luck
Old Feb 1, 2009 | 02:43 PM
mitch14's Avatar
CL in lawnmower status
all you do is get a pair of pliers, needlenose will work the best, grab the clip/tabs things and pull towards the car as hard as you can, the seat should "pop" up, that's all i did, i fucked up the hole by trying to remove the seat by just pulling up, goodluck
the tab things should just look like flat metal pieces laying flat against the carpet, probably with a folded end on them if i remember correctly
if you can take a pic to make sure we are talking about the same thing that would be great, but i'm 90% sure we are anyways
Old Feb 1, 2009 | 02:50 PM
I got the seat back out and im just going to leave the seat bottom in. Thanks for all your help.
Im posting a new topic of my new Idea, if you wanna help more go check it out in a few. :p
Old Feb 1, 2009 | 11:26 PM
s10httnswtchs's Avatar
yea they are a pain in the butt. i got so frustrated with them one day i ripped them out and screwed up the metal clip but oh well the seat lays down flat..
Old Feb 2, 2009 | 12:10 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
https://acurazine.com/forums/search.php
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
