Projectors
Old Feb 23, 2006 | 12:35 PM
wundumphaker's Avatar
Projectors
I'm wantin to retrofit my headlamps with projectors. I don't wanna go HID, no money. What Projectors should i buy? somethin affordable...
Old Feb 23, 2006 | 12:55 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
U can get 9006 projectors, I know integras have them, but if you're doing projectors, why wouldn't u want hid's?
Old Feb 23, 2006 | 01:32 PM
ib_jimmy's Avatar
^ yup if u're looking projector with 9006, integra would be the one. then in the future if you decide you wanna go with hid, just get a 9006 HID kit.
Old Feb 23, 2006 | 01:33 PM
alrite...thnx a bunch
Old Feb 23, 2006 | 01:35 PM
ib_jimmy's Avatar
its cheap and really easy to find too.
Old Feb 23, 2006 | 03:17 PM
Wouldn't any car's projector's work then?
Old Feb 23, 2006 | 03:20 PM
(Mid-Atlantic)
most projectors are designed for HID bulbs. You need a 9006 bulb projector
Old Feb 23, 2006 | 03:26 PM
and wat year integra?
Old Feb 23, 2006 | 03:27 PM
aah..alrite..thnx...sorry..i'm an idiot with all this shit
Old Feb 23, 2006 | 03:29 PM
(Mid-Atlantic)
I know 94-97 integras had 9006 projectors, because i've replaced them before on a friends car. You can search for the rest of the years, but try 94-97 9006 first
Old Feb 23, 2006 | 03:31 PM
Old Feb 23, 2006 | 03:44 PM
klepto's Avatar
if youre going to be spending money/time/effort into retrofitting projectors why WOULDNT you want to get HID's as well?
Old Feb 23, 2006 | 03:53 PM
cuz i don have th emoney....i'l upgrade to HID later. i'm findin the projectors for about 150 on ebay, where as HID would add another 300 to that, which i don have. unless you know of anythin cheaper
Old Feb 23, 2006 | 04:01 PM
jimmyeatmud's Avatar
Correct me if im wrong but I thought for HID you had to purchase like an entire new headlight w/ the HID projector in it. They don't make HID projectors for our cars (or alteast after searching for a while). I am confused.
ib_jimmy's Avatar
you should look for the audi a4 projector. much sharper and it take H4 bulbs then upgrade it to the HID later if you want.
Old Feb 23, 2006 | 04:02 PM
(Mid-Atlantic)
It's at least another $300, so far I'm lookin at about $800-900 to do my projectors w/ hid
Old Feb 23, 2006 | 04:03 PM
Straightline's Avatar
you can get HIDs for $240 on newcelica.org. the sponsor there has it for all cars and he has great service (purchased my d2s kit from him when i went retro, also got my original 9006 kit from him too).
Old Feb 23, 2006 | 04:04 PM
btw... you can get HID projectors for $90-100 and those are genuine audi d2s projectors (the best projos for new retrofitters cuz of their small size and great cutoff/color)
Old Feb 23, 2006 | 04:07 PM
ib_jimmy's Avatar
e.g. the 94-02 integra have projector but use the 9006 low beam bulbs. you can upgrade by just buying a 9006 HID kit that would just fit right in there. those kit usually run around $200-$300 a set.
when you're doing a retro fit it doest matter what projectors you're using as long as it fit in the housing of you CL headlight. projector that was design for HID would probably be sharper than projector that was design for halogen bulbs.
Old Feb 23, 2006 | 04:10 PM
ib_jimmy's Avatar
if i was you, i would look for the audi projectors...it will take the d2s hid bulbs and halogen H4 bulbs.
(Mid-Atlantic)
Keep in mind the 9006 integra projectors are not designed for HID and have heat and light output issues, my friend has an integra and was gonna buy new projectors for hid's because there are too many problems putting them on stock 9006 projectors. I looked into this, cuz I almost did the same thing we're telling him to do, but was worried about the issues with putting hid's on non hid projectors. That's why I got a6 projectors to use instead.
Old Feb 23, 2006 | 04:11 PM
Sumaccordguy1994's Avatar
ok, lets start fresh... integra projectors basically suck... especially with HID. And besides that, they'd be hard to mount as the internal bracket of the headlight is part of the projector.
Now, what you really want is probably a pair of MDX projectors. They use H11 bulbs, which run at 55 watts, you can easily fit H9 bulbs into those projectors which are 65 watts, good increase in light right there. The MDX projectors are quite small and would take very well to HID, a H11 HID kit would work great in them down the road.
Old Feb 23, 2006 | 04:12 PM
Thanks for the info. So if I picked up a set of 9006 HID projectors I could "retro fit" them into the housing on my headlight? From there I could install the 9006 HID kit? Also, I thought running HIDs w/o HID projectors was a good way to get lots of tickets.
EDIT: Everyones online right now, most of my questions have been answered thanks.
Old Feb 23, 2006 | 04:15 PM
ib_jimmy's Avatar
black, does HID run cooler?
i myself wouldnt go with the integra projector cuz you can find audi projector for pretty much the same price and its a much better projector.
Old Feb 23, 2006 | 04:19 PM
ib_jimmy's Avatar
it doesnt have to be 9006 projectors. that would just save you one step on the mod, which is getting a different harness for the bulbs. only reason you get a ticket for running HID is if you are running high Kalvin (sp?) bulbs, meaning it'll make it look too blue.
Old Feb 23, 2006 | 04:56 PM
If you go with true HID projectors, the best bang for your buck are the Audi TT/BMW 3-series Bosch projectors, they run around $90-$100 a pair and give very good output.
If you want to do a true retrofit, dont waste your time and money by using 9006 projectors and a "kit, get all OEM HID components.
HID bulbs get hotter than halogen bulbs, but give off much less radiant heat.
As for the origonal question, what I stated above about the MDX projectors is the best way to go.
Old Feb 23, 2006 | 05:12 PM
OK...hold on a sec....if i get the Audi A4 projectors, which run the H4 bulbs, will those bulbs work with my current 9006 plugs? or do i need to rewire all that shit?
here's another stupid question....if i decide to go HID right now while gettin projectors, wat would a good setup be, and how much would it cost? I'm tryin to go as low cost as possible on this!
Old Feb 23, 2006 | 05:18 PM
A4 halogen projectors use H7 bulbs, not H4. H4 bulbs are dual filament. The wiring is different with just about any different bulb, but small harness can easily be made or bought to make them work.
Your best bet, if you want to go HID now would be either valeo D2S (audi A4) or bosch D2S (audi TT/BMW 3-series) projectors, the valeos are a little more expensive but are great projectors, very small and excelent output. As for ballasts and bulbs, dont skimp... i highly recomend the Hella gen 3 ballasts as they're completly sealed and small, work excelent for any retrofit. Bulbs, stick with 4300K OEM temperature bulbs (either Philips or Osram), anything higher is a waste of money as you lose a signifigant amount of light.
Old Feb 23, 2006 | 06:08 PM
ok...sorry....would this setup work?:
HID conversion kit: to convert my 9006:
http://cgi.ebay.com/ebaymotors/NEW-X...38996970QQrdZ1
Projectors:
http://cgi.ebay.com/ebaymotors/Bosch...ayphotohosting
Old Mar 11, 2006 | 03:50 PM
Lockdown66681's Avatar
So r u guys saying that these will fit into my 98' cl? http://store.racinglab.com/98acinhaprhe.html, Or if not plz tell me what will !
Old Mar 11, 2006 | 04:10 PM
(Mid-Atlantic)
Those won't, you'd have to rip the whole thing apart, get a pair of audi or bmw projectors.
Old Mar 11, 2006 | 09:42 PM
Lunchbox's Avatar
Scissor Me Timbers!!
Kelvin
Old Mar 12, 2006 | 01:22 AM
Outlaw's Avatar
CL smashin
Too blue = less output = waste of money = rice = gay.
Old Mar 12, 2006 | 01:58 AM
krazy99cl's Avatar
O.G.
Dyme two pages and nothing...heh. jk.
best cheap or better yet..affordable way is to get some valeo h7 projectors...and get some OEM hids.....tt projectors are ok but i wouldnt get them....
or just start saving...its not hard...
check this package....http://www.hidplanet.com/package.html
save 50 or so a week or month and you should have it in no time...
who ever thought of the integra projectors...pls dont give advice if you dont know a lot about HIDS......first off...the reflector bowl on integra's suck...lens is cloudy/not clear...also the cutoff is not all that clear and sharp..equals poor lighting and not a good wide beam
Old Mar 12, 2006 | 11:35 AM
VXCL's Avatar
AWD Torque Monster
looks like your my replacement. i agree with everything he said. however valeo h7(audi) and hella h1 (jag) would be good choices and easy to wire. just change the bulb connector on the oem wiring. i would go h7 though if you want to throw a xenon kit in there down the road since h7 is much more common.
i would just save up $300-400 and do a d2s retro using some valeo audi s4 units. awesome cutoff and they already have a bezel containing the light. i have used the audi tt / e46 projector and while it is the easy to fit due to its size it didnt really impress me which is why i switched. i prefer audi (valeo over hella) but some hellas are close to valeos. the main thing is fitment. i would have went valeo myself in my subie but the hellas i used were almost made to fit in my lamps.
also i may have some h7 audi units i'll have to check. $65 shipped and they are yours with bulbs and bulb connectors if avail.
anything 9006 SUCKS!!!!!!!!!!!!!!!!!!!!!!
peace
Old Mar 12, 2006 | 11:42 AM
npchottboi's Avatar
I got a question then, i can get a pair of projectors from a 2006 lexus 430h. can i use these to retrofit?? i alraedy have a 9006 hid kit for my car, is this possible to do?? let me know before i fawk everything up please. thanks!
Old Mar 12, 2006 | 01:58 PM
krazy99cl's Avatar
O.G.
Those projectors are big, because the high beams on them. They use D2S bulbs and not 9006. Ive tried x5 E39 projectors and they almost didnt fit...
Old Mar 12, 2006 | 03:05 PM
VXCL's Avatar
AWD Torque Monster
exactly. thats what i squeezed into outlaws lamps. i forget who owns them now. you cant really go any bigger then that and contain them in the headlamp. i had hella bi-xenons but they would have never fit in the headlamp. i had to mount them from behind and aim them manually before putting the bumper back on. not fun, but oh well.
Old Mar 12, 2006 | 06:19 PM
LLWesMan's Avatar
Ahhhhhhhh
I have them.
Old Mar 12, 2006 | 06:27 PM
what projectors are in the 430h? looks like the bosch bi-xenons?
VXCL, do you still have the H7 projectors that came from your subie lights? If so, wanna sell 'em?
