Post lowering problems!
Old May 27, 2003 | 10:27 PM
DutchCLS's Avatar
01 CLS
I just had my CL lowered with pro kit and koni's a few days ago. Now my car has developed a squeak on the driver’s side, every time I go over a bump the driver side squeaks. Any ideas?? I'm a little concerned about this!
Old May 27, 2003 | 10:37 PM
nandowong's Avatar
Work safe avatar bish :D
it might be the coils of the springs rubbing
Old May 27, 2003 | 10:53 PM
DutchCLS's Avatar
01 CLS
I hope it's something as simple as that!!
Old May 27, 2003 | 11:21 PM
Katies99CL's Avatar
i want a bimmer =(
when i lowered my accord i had the same exact problem...i took it to the honda dealership and of course they found something wrong, like i needed to oil god knows what...but the end result did help the noise...so it was a wasted $235...
i doubt anything is seriously wrong w/ the car...my suggestion to u is just turn up your music...it'll make the noise go away
VXCL's Avatar
AWD Torque Monster
make sure everything is torqued to the right specs. not too much not too little. make sure the springs are seated in the upper pads correctly, and make sure lower part of the spring is seated correctly. also who installled them for you?
Old May 28, 2003 | 11:41 AM
DutchCLS's Avatar
01 CLS
I checked with Acura and there is no recall for the ball joint for my car.... the shop that installed my suspension is pretty reputable so I'm not to worried about them doing something wrong........
Old May 28, 2003 | 12:57 PM
r3mix3r's Avatar
my car makes a noise when i got over a bump, when i turn, when i do anything. squeak, clunk, click everything. I just try to keep music on. i feel like my car is gonna fall apart the sound it makes when i go over sumtin or if i turn the wheel all the way.
Old May 28, 2003 | 01:05 PM
Jawo's Avatar
Have someone help you check the springs. I agree with VXCL. The problem may be simply the springs not sitting right on the perch. So without the help of the springs, the shocks might be taking all the beating, consequently making the squeaking noise. Hopefully, this is the problem and this shouldn't cost you much.
I hope this helps.
Old May 28, 2003 | 01:57 PM
DutchCLS's Avatar
01 CLS
Hopefully it's something minor!!
Old May 28, 2003 | 03:18 PM
benzo555's Avatar
boo
Same here.. Had the problem on my old 99 Accord. The problem was a worn bushing.
Old May 28, 2003 | 04:30 PM
VXCL's Avatar
AWD Torque Monster
I TOTALLY FORGOT!!!!!!!!!!!! the rotor heat shield rubs like a bitch on the end the lower arm!!! if u drop bout 1.8" or more. its a nice sqeeky metal sound
Old May 28, 2003 | 06:14 PM
Casper98CL's Avatar
You Fawkin Kiddin Me!
sounds like a bushing.. possible the sway bar or from the prich.... even rubber stopper in the spring..
Old May 28, 2003 | 08:42 PM
DutchCLS's Avatar
01 CLS
VXCL,
I will check that out!!
Old May 28, 2003 | 10:59 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
damn theose ball joints...that went out on mine, then the HUB and then it threw my WHOLE alignment outta wack, by the time i caught it, well it was too late, $400 later and NO more tire tread, life now seems to be gettin better for the CL...i hate when that shit happens though..and u cant figure out what it is until WAY later..
Old May 29, 2003 | 01:31 AM
platinumCL's Avatar
I've had my pro kits for a little over 2 years now, with the same squeeking. Except mine only does it when i'm at a complete stop and i turn the wheel. Never bothered me much, so i've just been ignoring it.
Old May 29, 2003 | 03:05 AM
DutchCLS's Avatar
01 CLS
I'm just worried that it's a worn ball joint or bushing. I don't want anything falling apart while I'm driving..........
Old May 29, 2003 | 03:26 AM
VXCL's Avatar
AWD Torque Monster
its the your rotor dust and heat sheild!!!!!!!!!!!!!!!!!!!!!!! bend it away from the lower arm and ur sound will be gone of it hasnt worn away enough yet
Old Jun 3, 2003 | 08:11 PM
r3mix3r's Avatar
VXCL, Is this normal to just happen like all the sudden for example 6 month's after drop? It happens(metal cling sound) when i hit a bump or sometimes while making certain turns...It sounds like if u were to spray the sheild w/ a hose or sumtin. How do i know if its this? And how i fix it?!?!? THANKZ! ! !! !
Old Jun 4, 2003 | 04:09 AM
baka_t's Avatar
The movement has started
when i 1st dropped my car using skunk2 coilovers there was a burning smell as if you just drove down a steep hill...its squeaks like mouse and its bouncy as hell shoulda went with the teins BLAH!..o well hopefully with the agx's it will be a lil better..hopefully..
Old Jun 4, 2003 | 12:36 PM
VXCL's Avatar
AWD Torque Monster
just bend the bottom of heat sheild away from ur wheel. if u take ur wheel off u should see a nice marks in ur heat shield.
Old Jun 4, 2003 | 04:24 PM
r3mix3r's Avatar
Why did it just happen now after 6 months?
Old Jun 4, 2003 | 04:25 PM
-=DjPharmacy=-'s Avatar
A-CL CrAckHeAD
Got Camber? if you have the Specialty products camber kit (nopi kit) It sux. Bushings squeak bad after a while - i replaced mine - NO PROBLEMS - NO SQUEAKS - NADA!! GO INGALLS KIT!!
cycdaniel
Dec 17, 2019 10:58 AM
marcelft
Jul 10, 2018 06:17 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
urbtsx
Mar 4, 2017 06:53 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
