Please help me save my window :(
Work safe avatar bish :D
I know eveyone knows where this is going My window got stuck down and would not go back up. This happened to the drivers side, which was not showing any sings of malfunctioning.
The real unusual thing is that the window would go down when i pressed up. it would go down 3-5 inches before getting stuck. I think the motor is still good because it spins and pulls the window down (even though is supposed to go up instead)
I took the door apart and finally got the window to stay up.
while doing this i found a cable that was out of place i think this is whats causing it. I know almost everyone here has had this great experience with the great quality of acura window regulators (rick, i know you have gone through a couple, or should i say 5-6) dont mean to jinx you or anything, just looking for help
here are some pics of the out of place cable
http://us.f1.yahoofs.com/users/b26a1....ht0.AvOOAhL_X
http://us.f1.yahoofs.com/users/b26a1....ht0.A8uZBifJR
I can't really tell anything by the pics.
The cable broke on all of my regulators (4)! :angry:
Like bzboy says, check out eBay (if your's is broke). I've seen them for $75-$80. Dealer charges over $250 (including installation).
However, if it's just "off track" (which I doubt), you should be able to figure how to put it back. Worst case scenario, remove the other door panel to see how it should be aligned.
Good luck.
Good luck.
A week after I got my CL, the driver's side went down with a grinding noise and never came back up. Pretty aggravating since it happened at 12:15 on a Saturday and the Acura repair shop shuts down at noon and doesn't re-open until Monday. The extended warranty I bought covered the repairs, but I still had to spend the weekend feeling naked. I know it is just glass, but when it's not there I feel like my car is really vulnerable. I feel your pain! Good luck.
OMG same thing happen to me last week. What it is, is the cable is tangle up inside the motor i bet just like mine. this rubber part that suppost to keep the cable like up even like is worn out so the cable is all over the place inside the motor. What i hate is u have the buy the motor, cable, and rail all together because of the cable. $119 on www.acuraautomotive.org
What suck when this happen to me that night.....it start rainning...didnt look like it was tho. my car was wet!
I have the panel off and im driving around with my tools and the door panel in my back seat does anyone know how to disconet the assembly? I have the motor unscrewed but i dont know how the cable attaches so i can unplug it. the motor is fine, is just the cable that is out of place. btw. if i take the assembly out will the window fall down? any tips are greatly appreciated, thanks guys for your help
I off today so im going to try and fix this today. I will let you guys know how it went. But if anyone can tell me how to unplug the cable from the window i would really appreciated.
yeah you have to take all those bolts out...one of the bolt that's holding the window you'll have to move the window down until you see the bolt threw this round hole on the panel. and yes the window will drop when you take the assembly out.
My parts is coming in Thursday!! i can't wait to roll around with my window down.
i was gonna get it off the 2dr honda accord but the part number was different and i can't find an accord 2dr at the wrecking yard anywhere around here. see i thought my motor was out too but its the part next to the motor where the cable run threw that's mess up.
xsilverhawkx
09-28-2015 06:51 PM
