please help, car wont start
please help
my car wont start, the head lights, dash board, and radio turn on okay. the engine gives a clicking sound when i try to start. ive read on these forums to tap the starter and battery, but i dont know where the starter is. im a real noob when it comes to engines, so i may need some specific detail on where to find it. thanks for any help you can offer.
Originally Posted by Mulk
its most likely the starter if the battery isn't dead..
Starter, especially if it's clicking. Did you change anything on the car?
When it clicks, does everything flicker.... Is your clock wrong, and your presets gone? If so, it ain't your starter. Get a jump and go with all your accessories off. Drive around for a bit and then go to Autozone and have it tested. I bet it won't hold a charge under load. Then you will just be out $65.00 for a battery.
yeah, first check your fuse in the fuse box, if you dont know which fuse is the right thing..
check all for 15 number on the side of the fuse.
I had a same problem.
Maybe other problem you could have, but try it!
You should go get a multimeter if you don't have one already, then you can check the battery yourself. It should read right around 12 volts-give or take 1.5 v-when the ignition isn't on. If you get your car started the battery should read around 14 volts. With the car running and the multimeter on the battery have someone turn on your headlights. If the voltage on the battery drops when the lights are turned on....then you have a bad alternator.
thanks for the replies. i ended up having to get it towed so i wont get a parking ticket. i did try a jump, but that didnt help. i also disconnected the battery and my clock and radio reset. i had the altenator and the ignition switch replaced preiviously. its a 97 3.0 with 130,000 miles or so and the shop i took it to replaced the starter for $300. im not sure if that was a rip, but it was the closest one to my apt. thanks again for the help.
saberlove
Mar 11, 2021 09:29 AM
bearingman07936
Jan 7, 2016 03:22 PM
