PAC Box
PAC Box
http://www.electronixwarehouse.com/c...s/pac-sni8.htm i ordered this the other day for the cl, will this work out fine... thanks
it will work, but its best to get a better converter because they will filter the amplified signal w/ less noise interference and give a stronger signal to you amps. the SNI35 picks up upto 20-30 watts.
you should just have to hook it in-line with your rear speakers + and - wires, than connect the line out to the amplifier. I usually consult the manual for color codes to the factory wiring.
just a piece of FYI - the factory radio only puts out 7 watts RMS, so you should be fine with the one you got. However if its a bose system i can't help you out.
They say for best results connect it directly behind the head unit closest to the source unit. However, i've connected it to the rear speakers directly before the speaker and have never had any problems. Also, is there a factory amplifier in the car? Are there speaker wires or a single black cable connecting into the rear speaker. If so this may be a bose amplifier and may require a different, more specialized part to connect to it. Let me know i should be back around some time later tonight.
4drviper
Apr 23, 2025 07:13 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
