Okay...could this be the problem???
Old Jul 31, 2001 | 12:13 AM
leolism's Avatar
Sorry to be so annoying...
Please take a look at the pictures of my springs.
underhttp://photos.yahoo.com/leolismcls
under the "Installation Problem" folder.
Did the shop I went to incorrectly installed my springs???
My springs seems to be up-side-down compare to the CL in drive.to/acura-cl!!!
You can see in the pic that the super tight part of my springs are on top while drive.to/acura-cl has the tight part toward the bottom.
Did the shop installed my springs incorrectly?
Is this normal?????
Thx for the help
Leo
Old Jul 31, 2001 | 12:21 AM
RidinLow's Avatar
Scooby Guru
I don't think that's it, unfortunately. It doesn't matter if the progressive section of the spring is at the top or the bottom because the top mount and the bottom mount will see the same spring diameter and spring rates regardless of orientation.
However, you will get funky noises if the springs aren't oriented correctly in a rotational fashion, i.e. if the spring is twisted a few degrees off center.
Old Jul 31, 2001 | 12:22 AM
KikAzCL97's Avatar
Sorry I cant help you with your problem. As for being annoying dont worry about it that is what this forum is for. We are all about helpen each other out.
Old Jul 31, 2001 | 01:11 AM
3PointZero's Avatar
Jesus, you are starting to get really annoying here
Old Jul 31, 2001 | 01:12 AM
3PointZero's Avatar
Just kidding, I love you.
Old Jul 31, 2001 | 01:19 AM
DigiBox's Avatar
Lots of JDM parts on my
I am wondering if the front springs were put on the rear. Definately looks different from cldriver's pics. Also, are the pics you took of each side? It looks like one was installed upside down.
[ 07-30-2001: Message edited by: CiLver2.3 ]
Old Jul 31, 2001 | 01:21 AM
ModedGen1CL's Avatar
no it looks okay if i remember it shouldnt make a differencce the think i would have done is what i am get tru coilovers they dont mess up suspension or anything
Old Jul 31, 2001 | 01:28 AM
3PointZero's Avatar
It looks fine from the pic. Make sure the dust boot on the strut isnt rubbing on the springs... I had ground control coilovers on my old car and the boot was rubbing which caused lots of noise. Did you have struts installed too?
Old Jul 31, 2001 | 01:34 AM
leolism's Avatar
Nope, just springs.
Old Jul 31, 2001 | 12:24 PM
3PointZero's Avatar
Maybe your struts are busted?
Old Aug 1, 2001 | 12:16 AM
true struts could be busted i would still have gone with tru coilovers
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
