Odd Problem - Maybe distributor issue???
Old Sep 8, 2004 | 12:32 PM
xenocron's Avatar
I'm not new to cars but my new daily driver is a CL 2.3 premium, think I got it at a steal for $5,700 with only 90k...
Anyways, didn't really know how to search for this *issue* and you guys seem pretty decent compared to most boards I frequent...
So my issue is while accelerating, my car does this "jumpy" thing. Yeah, I know, really descriptive. What I mean is it has short, small bursts of power. Particularily it is more noticable while the A/C is on, but is also noticable without. Feels kinda like the timing suddenly, advancing...giving a short burst of power. Annoying and worse off who knows what could be going on that might be pretty detrimental.
I put in new plugs and that didn't seem to help. I do want to and know I should also replace the cap and rotor. I will also be doing a timing belt soon (haven't decided to do it myself yet or not).
Any thoughts or people that have felt this same thing and could chime in I would appreciate it.
Chris
Great site BTW...Glad I stumbled across it.
Old Sep 11, 2004 | 06:08 PM
xenocron's Avatar
No love
Any guesses at all?
Old Sep 12, 2004 | 01:30 AM
krazy99cl's Avatar
O.G.
my dads truck did the same thing.....basically your car is auto right? when it changes gears it jumps right? well then its your tranny....i would change the tranny fluid first....then it it persist then sorry to say it may be your tranny.
Old Sep 12, 2004 | 08:09 AM
wilp99's Avatar
sounds like the idle air control valve (IAC). not too hard to change, u could try cleaning it first, but if cleaning it doesent fix it replace it.
Old Sep 12, 2004 | 06:03 PM
xenocron's Avatar
it's a manual...and its definitely not a tranny issue
Old Sep 12, 2004 | 06:04 PM
xenocron's Avatar
Idle air control valves only help the car get a little extra bit of air at idle...not accelerating which is when this happens for me.
xenocron's Avatar
Thanks for the ideas...any others?
Old Sep 12, 2004 | 06:57 PM
VXCL's Avatar
AWD Torque Monster
clogged fule filter? run some cleaner through it. cap, rotor, air filter should be changed for the hell of it. myabe ur vtec soleniod is messed up. not always activating when it should
Old Sep 12, 2004 | 10:13 PM
xenocron's Avatar
Yes I def need to do that basic stuff, it could be a cap/rotor thing...I was also wondering if the VTEC solenoid was acting up...on my LS turbo integra I don't have to worry about VTEC so I never learned much about it...
Any thing you can test to see if the solenoid is messed up? I'm pretty handy with a DVOM and I have been trying to locate a Helms on here to do some troubleshooting but no luck yet.
Old Sep 12, 2004 | 10:23 PM
VXCL's Avatar
AWD Torque Monster
i have a helm back home in nj. where in northern nj are ya? if your not far you should come by when im around and see if we can figure out the prob.
Old Sep 13, 2004 | 07:25 PM
xenocron's Avatar
I'm in Bergen County...I'd love to meet up if its close.
PM or send me an email.
Old Sep 13, 2004 | 08:20 PM
VXCL's Avatar
AWD Torque Monster
as long as my rims show up i should be home 1st weekend of octber 1-3
Old Sep 25, 2004 | 06:44 PM
Tosh's Avatar
Eurotrash
On my 90 Legend, oil was seeping into the distributor cap, causing some stumbling. I would clean out the cap and rotor, temporarily fixing the problem, but eventually it would happen again. I replaced the distributor, since it had a bad seal, and problem was gone. Hope that helps...
Bad plug wires can also be hard to diagnose. As they get older, they will develop internal cracks which change their resistance with movement or vibration. If in doubt, change them. It's part of a tune-up anyway...
Old Sep 28, 2004 | 10:30 PM
xenocron's Avatar
Good advice...thanks for the tip!
Old Sep 29, 2004 | 01:37 AM
LCARUCA 97's Avatar
Trailblazer = SUCK
its the coil, icm, or the o2 sensor
try unpluggin the o2 and see if there is any difference. otherwise, take it up to autozonr and have then test your icm and coil to make sure they are in spec.
Old Sep 29, 2004 | 11:12 AM
wilp99's Avatar
check ur plug wires, ours have a tendency to pop out of the holes. and come off the distributor.
especially if ur using bosch platnums.
Old Sep 29, 2004 | 03:36 PM
ju5tchi11in's Avatar
roomate has a CL too
same thing happens to me i got the 2.3 manual i rarely use the A/c because it makes my car feel like i have 100hp... and the lurching.
never figured it out... one time i got a check engine light for the vtec pump or something... i think it was because i had low oil...
so don't know what the problem could be. still happens to me.
Old Sep 30, 2004 | 11:11 PM
xenocron's Avatar
I didnt know Autozone did that for you...
Otherwise its just making sure there is at least 400Ohms of resistance across the (+) & (-) poles of the ICM or coil, right?
I have a DVOM so I'll have to check that out...
Old Oct 1, 2004 | 04:46 PM
F22CL97's Avatar
Same problem
I had the same problem w/ my Cl. Eventually I took the D-cap off and found that it was arching at the points so I just replace the D-cap and the coil w/ a new msd cap and coil along with some good wires. That got rid of the jumpy acceleration for me. Hope this advice isn't redundant.
Old Oct 2, 2004 | 11:03 PM
legendaryCL98's Avatar
'07 November = STI
maybe the fuel injector is clogged..
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
carz0159
Sep 20, 2015 06:11 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
brandnewcolony
Sep 12, 2015 10:39 AM
