new rotars, ?help
05' 350z 6spd.
new rotars, ?help
Hey my steering wheel is shaking REAL BAD when I brake. I just had the alignment done, and they said my rotars are pretty bad. I'm gonna get new ones, probably off ebay and this is my question.
Are the 97 and 98-00 rotors any different?
Most of the ones I found say 94-97 accord/96-97 cl. I hate how all these companies swear that theres a 96 CL! Just a little confused, and I know some of you have replaced yours, so let me know if they are different. Thanks!
A-CL Post Whore w/N2O
Re: new rotars, ?help
The rotors are designed differently between the '97 and '98/'99 models.
Front rotors from the '97 models are the "hub-over-rotor" design. This means that the hub has to be pulled off before you can get the rotor off (about a 4-hour job--without a hub puller).
The '98-'99 rotors are the "rotor-over-hub" design. With these, you just remove the rotor and don't need to touch the hub (about a 45-minutes job).
You'll need to purchase front rotors for the '98/'99 2.3CL.
BTW: I think a lot of companies confuse the '97 CL as a '96 (since technically, it was released in '96 as a '97 model).
EDIT:
Here's a pic I have showing the '97 front and rear rotors. The ones on the left are the '97 front rotors (notice the pattern of the center area). Even though the ones one the right are for the rear, they pretty much look like the '98/'99 front rotor design (notice the pattern of the center area).
05' 350z 6spd.
ok, thanks a lot dust!
There is no rotors for 98's on ebay right now, so i'll just keep looking. I'm glad to hear is a pretty easy job cause I hate paying for installs.
Originally posted by jorgev
ROTOR puller?? what is that and how does it work...
i cannot change my rottors because i cannot get them out!
05' 350z 6spd.
Originally posted by 30CLstyle
hey, I have a full set of rotors for 98/99 2.3 CL, they are cross drilled and slotted rotors, I need to sell these,
so the 98 rotars are just bolted on or what? I just want to know what i'll be doing before I start it. Glad i don't have a 97!
Gimmie my points Biatch!
05' 350z 6spd.
Id like $200+shipping for the set of 4, I paid $250 for them just to sit in my room for the past 6 months
01blaackAC
01-30-2006 03:01 PM
