My car died today...
05 STi White/Gold
It just cut off while i was driving. I could hardly turn the steering wheel to get off the road. dunno what the fuck happened. luckily i didn't get into an accident. my battery and oil? (the one next to the battery) light flickered for a couple of seconds. has this happened to anyone? what happened??? thanks...
05 STi White/Gold
any chance that it could be the battery? would i have to go to the dealer for this, or can i go to some local car shop to get it fixed???
05 STi White/Gold
thanks for your comments guys... so it's either the batter, alternator or distributor. any ideas on costs? how bout at the dealer? i've never done a dealer service before since i bought the car... might be time...
Not AtlCl98 or Atl-CL
Did your ignition get replaced with the recall? That could be it because the in the recall description it says that the faulty ignition switch would cause your car to shut off while driving. Check with the dealer about that. That should be replaced for free
My Home Planet
It wouldn't be just the battery. It would be the alternator and then you may have to get a new battery if you can't recharge your existing one.
If you haven't had the ignition recall done, it's a 90% chance that's the problem.
05 STi White/Gold
Moderator Alumnus
hmm.. check to make sure that the pos. and neg. are tightly clamped onto the battery.
also check to see if you still have your alternator belt. i know it's a "duh" kinda thing..... but im throwing other options out.
Sign: Slippery When Wet
If the battery is 3 years old this is your best bet. Most cars today will not run on the alternator alone. A trip to a gas station that does mechanic work will be able to check the battery in about 5 min. and tell you if this is the problem. If you have to, disconnect the battery and take it to the gas station.
05 STi White/Gold
Originally posted by jaysCl
I had the same bullshit happen to me the second day I got my car. the problem was the alternator.
05 STi White/Gold
Originally posted by gjr2001
Are you sure it's the battery?
05 STi White/Gold
The alternator would most certainly be your best bet. I would truly doubt it would be the battery.
An Official Cl Whore
Why don't you upgrade your alternator? Sounds like he wanted to sell you a battery too. The battery is only needed when the alternator cannot handle the load (when the car is running of course). Unless you like to sit around bumpin in accessory mode. Thus the only time to upgrade a battery is when you need small power gains such as 10 amperes or less. BTW a rebuilt alternator should last nearly or just as long as a new alternator.
