lowered
Old Nov 19, 2003 | 05:55 PM
CL-zero's Avatar
lowered
i lowered my 98 CL 3.0 like 5 weeks ago.
I bought Eibach springs ang Tokico shocks.
lowered like 1.5 inchs and do i need to do alighment for it?
i have not do alighment yet. i'm broke
how bad do i need to get alighment?
it drive just fine.
Old Nov 19, 2003 | 06:11 PM
pmp93cl's Avatar
eibach pro or sport kit
Old Nov 19, 2003 | 06:22 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
You need an alignment. The issue now is whether you'll need a camber kit.
If the drop is 1.5", you probably won't need a camber kit (however there are peeps on the baord that are having uneven tire wear even just with a Pro-Kit drop). If the drop is over 1.5" (like with the Sportlines, you'll need a camber kit or your tires will wear unevenly.
Old Nov 19, 2003 | 07:11 PM
CL-zero's Avatar
what will happen if I don't get Alightment.
I can just rotate my tire and solve that problem, can't I?
I think i got Sport one from Eibach
Old Nov 19, 2003 | 07:13 PM
hornyleprechaun's Avatar
Bent = #1
Old Nov 20, 2003 | 07:52 AM
ATLcl98's Avatar
Atl/Mia reppin'
Don't try to find a way out of an alignment...how do you expect your alignment to stay within specs when you lower it? Hell, if you're at stock height and hit a big pothole your alignment may go out of wack....so just get the alignment done. If not you'll be whining in a few months about how your tires are already bald and your car is veering to one side on its own. Just do it!
Old Nov 20, 2003 | 08:41 AM
You'll wear out your tires very quickly (and unevenly).
$$$ spent now on an alignment, will be only a fraction of new tires (let alone the stress you're putting on your suspension).
Old Nov 20, 2003 | 08:53 AM
r3mix3r's Avatar
If you got Sportlines w/ Tokico you will definitly need an alignment and an extreme camber kit. Either Ingalls or SPC...Trust me I learned the hard way...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
