lights went out
lights went out
actually the power locks went out like a month ago, the left headlight went out next then the right and last night the taillights , i cant drive around with no taillights so please help me fix it, btw the brights work
Most likely a switch/relay failure since I am pretty sure the headlights and taillights are on separate fuses. A lot of cars even have the left and right side lamps on separate fuses so that a fault in one circuit doesn't take out both sides. good luck
are you sure you checked the fuses in the car and under the hood and what did u test the fuses with did u pull them out and look at them or did you use a fuse tester if so you have to check each side of the fuse sometimes it`ll light up on one side but doesnt mean it still works
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
Good point, sounds like a relay
