Just did seafoam...here's a little how-to just in case
Old 03-23-2009 | 01:45 PM
  #41
GhettoNinja06's Avatar
Skuuuurrrrrt!
The T-Connector is the vacuum lines on the back part of the engine
Alright, I think I see it back there. I'll take apart the hose the left?
Old 03-23-2009 | 01:49 PM
  #42
combat mediC's Avatar
vaccuum lines, just like I said noob.
Old 03-23-2009 | 01:56 PM
  #43
Skuuuurrrrrt!
^Yeah, thanks bro I got it. I just wanted to know which line because I didn't really feel like checking which one sucks or not. Haha.
Old 03-23-2009 | 11:33 PM
  #44
Skuuuurrrrrt!
So I seafoamed! There was ALOT more smoke then I thought... It was alot more grey in color than the vids I've seen too.. I first started revving it and was like, wow, that's alot of smoke. Then I put it in drive and floored it up the hill and DDAAAMMMNNNNN!!!! I felt like I hit the smoke screen like in Death Race or something... BUT the hilarious thing is that one of my neighbors was walking out of the front door, I flew by, I look in the rear veiw mirror throught the thick smoke, she was submerged in the smoke and see her run back in the house!
Performance wise, I could deff feel it pull harder. Fresh oil change tomorrow!
Old 03-23-2009 | 11:43 PM
  #45
since you're changing your oil, dump some seafoam in there today, its safe.
Old 03-24-2009 | 12:04 AM
  #46
Skuuuurrrrrt!
Already did. 1/3 in gas, 1/3 in oil, 1/3 vaccum line all at the same time. Let it sit for 10 minutes then started the fun. Thanks for the help guys! :gheyhug:
Old 03-24-2009 | 02:59 PM
  #47
SpAzZy's Avatar
any noticeable differences? i bought a can today after reading this thread and reading up about seafoam. they had it at a local pepboys for $10. worth a shot i guess. i've seen some mixed reviews. a lot of ppl were saying not to put it in the crankcase cuz it may leak afterwards if the sludge/dirt was what was keeping the leaks from happening.
main reason i want to try it is because my idle is all crazy nowadays. it drops really low when i'm sitting in drive at a light and if i'm in park and rev it at all, once i let off the gas it will drop off lower than where it started and then go back to normal idle rpm after a bit.
i'm going to try half in my gas tank and half through the vacuum line. just scared of all the smoke and scaring my neighbors. cops are assholes in my town, i'll probably get pulled over when i'm driving it out
Old 03-24-2009 | 03:11 PM
  #48
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
So what part of the t-connector did you use fred?
Old 03-24-2009 | 08:06 PM
  #49
Skuuuurrrrrt!
The car deff pulls harder and idles smoother with the A/C on. I still run mid 7 second 0-60 runs though. It's more about smoothness. Oh, I did also have a problem before starting my car. It sometimes wouldn't start the first time I would turn the key which was probably because of clogged fuel injectors (I would ALWAYS run the car on fumes...) but so far, It's always started right up and like I said, smoother idle.
The tube to the right of the 'T' connector. The one that runs toward the engine.. haha.
Old 03-24-2009 | 08:12 PM
  #50
mitch14's Avatar
CL in lawnmower status
hmmm... i've been wanting to try this too, but when i researched it there were quite a few people saying it's harmfull for the engine.
I want my cl to run a little smoother, but i don't want to risk it, as it's getting pretty high in mileage (near the equivalent of 180k miles.) hmm decisions...decisions..
Old 03-24-2009 | 08:13 PM
  #51
Skuuuurrrrrt!
As long as you do it right and get an oil change afterward then you should be fine.
Old 03-24-2009 | 08:18 PM
  #52
mitch14's Avatar
alright, maybe i'll try it this summer.
i just have a tiny oil leak, so i hope it doesn't make that any worse still gotta get that checked out too
Old 03-24-2009 | 11:48 PM
  #53
(Mid-Atlantic)
just don't do the crank
Old 03-24-2009 | 11:50 PM
  #54
#1 STUNNA's Avatar
Sanest Florida Man
I bought a gallon of seafoam last year and have been using that. I need to seafoam again cause my idle sometimes gets fucked up and I want to see if this will help but it probably won't.
Old 03-25-2009 | 08:59 AM
  #55
SpAzZy's Avatar
this is exactly what i'm looking for, smoother idle.. especially with A/C on. i run on fumes pretty often too, just don't like making a trip to the gas station when it's not on the way to where i need to be going. i'm not expecting it to make the car any faster, just run smoother. thanks!
i was reading the older posts too, i don't really feel comfortable just taking tubes off the back of the engine without knowing exactly which one it is. any pictures? or anyone mind taking any pics on a 3.0?
Old 03-25-2009 | 12:47 PM
  #56
Tehvine's Avatar
6spd FTW
Did mine a few minutes ago (2.2) definitely idles much smoother. Now it's up on jack stands draining the oil, I put some in the crank too.
Old 03-25-2009 | 01:09 PM
  #57
champstar's Avatar
a suggestion to the ppl who are worried about all the smoke........ do it early in the morning like 5 or so
thats wut i plan on doing
Old 03-25-2009 | 01:35 PM
  #58
(Mid-Atlantic)
Screw that, I'm smoke screening my neigborhood
Old 03-25-2009 | 02:56 PM
  #59
Tehvine's Avatar
6spd FTW
So.... talk about getting the shit scared out of you. Prior to my seafoam today, I went a bit over my oil change interval (1500mi over). I finish the seafoam no problem and move onto the oil. I finish the oil and back the car out etc. Now, as I was cleaning up I got the living hell scared out of me.
I found this in the bottom of my oil drain pan (aka: litter box)
So after about 45 mins of freaking out and starting the car to listen for noises... I decided to cut the oil filter to shreds to look for metal. Ripped it completely apart with all of the filter media out... nothing, not a spec. At this point I am completely puzzled. So I looked to my left and lo and behold, there is my normal oil drain litter box nice and clean and it finally clicked. I never fully cleaned all the metal shavings out of this pan after I did the trans swap in the accord Just figured I would share my scary brainfart of the day.
Old 03-25-2009 | 03:54 PM
  #60
(Mid-Atlantic)
I would have a heart attack too
Old 03-25-2009 | 05:47 PM
  #61
shogo2.3cl's Avatar
I AGREE!!
i did this on a old 92 4 banger mustang i had and 3 days later i was at advanced auto parts ordering a new crate engine for it.
My mechanic said that it was because my engine had such high miles and the gunk buildup was keeping my piston rings sealed up nice and tight.
This seams like something you would do on a new car every 6k or 75 hundred miles not something with 180k miles or whatever. but its cool nobody has had any problems with it
Old 03-25-2009 | 08:00 PM
  #62
Tehvine's Avatar
6spd FTW
Originally Posted by shogo2.3cl
I AGREE!!
I used to read through all the seafoam arguments and I remember someone bringing that up. Another guy replied (supposedly a mechanic) and pointed out the obvious. Your rings cannot be sealed by gunk unless your pistons decide they don't want to be forced against the cylinder walls at all during their stroke.
Old 03-25-2009 | 08:11 PM
  #63
Skuuuurrrrrt!
That one. Makes sense since it's the only tube leading to the engine...took me a while to figure it out. Be sure to cut off part of the tube that you stick in the seafoam because that part could crack due to expantion and what not.
Old 03-30-2009 | 11:13 PM
  #64
#1 STUNNA's Avatar
Sanest Florida Man
^you don't need to cut off the tube. I've seafoamed my car almost ten times and I've had no problem with the tube, no cracking no nothing.
Old 03-31-2009 | 11:04 AM
  #65
Josh99CL's Avatar
What's the highest miles anyone has foamed for the first time?
I'm sitting at 123k and I have some reservations.
Old 03-31-2009 | 11:32 AM
  #66
PimpCL23's Avatar
contrarian in fashion
Damn.. 10 times??
i havent done this shit once yet!
maybe its time... especially for my integra with 294k miles on it!
Old 03-31-2009 | 11:36 AM
  #67
Josh99CL's Avatar
Originally Posted by PimpCL23
Damn.. 10 times??
Foaming a car for the first time with 300k on it would be scary. I'm a little reluctant to do it on mine with 123k. If it doesn't unplug any grim plugged leaks you'll probably shit your pants with how much better it runs.
Old 03-31-2009 | 01:43 PM
  #68
SpAzZy's Avatar
i'm at 126k. i bought a can a few days ago and haven't tried it yet. pretty hesitant myself. i think i'll be trying it soon though, right before i get the free work/parts (warranty) from acura.
Old 03-31-2009 | 02:11 PM
  #69
Josh99CL's Avatar
Let me know if you have any leak problems.
Old 03-31-2009 | 09:07 PM
  #70
SpAzZy's Avatar
i only plan on putting it through the t-connector and gas tank. not in the crank case.
Old 04-01-2009 | 11:29 AM
  #71
PimpCL23's Avatar
if the engine gets messed up.. i wont be too worried.
itll give me an excuse to do a swap
Old 04-01-2009 | 11:51 AM
  #72
Josh99CL's Avatar
I'll probably do this once I get my exhaust system fixed and hope for the best.
What benefit do you get from sucking some through the vacuum hose? What exactly gets decarbed?
Old 04-07-2009 | 11:50 PM
  #73
PimpCL23's Avatar
With the help of Palayahata and Brent... we did a Seafoam to my teggy!
with near 300k on the Odometer... the car felt great!
heres some pics of the smoke screen down the block! LMAO
Old 04-08-2009 | 08:21 AM
  #74
asianspec's Avatar
did you change your oil?
Old 04-08-2009 | 09:52 AM
  #75
Josh99CL's Avatar
Pimp what all did you foam? Gas,Crank,Vacuum?
Old 04-08-2009 | 11:52 AM
  #76
(Mid-Atlantic)
was 6 pics really neccessary?
Old 04-08-2009 | 11:55 AM
  #77
Josh99CL's Avatar
I wouldn't believe him unless I saw the smoke from every angle.
/sarcasm off
pic #2 or 3 would have been plenty =)
Old 04-08-2009 | 12:29 PM
  #78
(Mid-Atlantic)
Old 04-08-2009 | 03:27 PM
  #79
PimpCL23's Avatar
yes
Old 04-08-2009 | 05:31 PM
  #80
asianspec's Avatar
was your post necessary?
Quick Reply: Just did seafoam...here's a little how-to just in case
