Instructions on replacing window regulator
Old Jun 14, 2003 | 07:42 PM
nandowong's Avatar
Work safe avatar bish :D
Ted asked me for instructions and i tought i would post it for everyone that needed it. feel free to criticize if i told something wrong or if i forgot something. this is just a two minute quickie
here is what mine looked like, awesome acura quality
my finger is pointing to the left bolt, there is a little hole above the right bolt next to my finger. you have to make the window go down so you can see the bolts through that hole. you need a rachet extention to get the bolt through the little hole. the bolt on the left can be accessed through the large opening on the left. these bolts hold the glass to the regulator. when you take them out the window will fall so you will need some one to hold it. when its loose you can pull it all the way up and get it out of the way.
next take out the two bolt where my finger is pointing.
next take out the two bolts on top. you have to pull the door opening handle to get the metal bar out of the way. once you get all four bolts out you have to unplug the regulator out.
and the three bolt holding the motor in place. then the whole assembly will come out.
then repeat the steps to put it back in. make sure all the bolts are back on the rail and on the motor. i forgot to put the top ones back on and had to rip the whole thing again but it was good practice. once the motor is installed use the window button to make the motor go up to where you can see the bolt through the little whole and attach the window and you are done. if the window has trouble going all the way up (like mine did) loose it up and pull it to your right and tighten again and keep trying it until it become aligned. btw take advantage that the panel is off and grease the rail up. let me know if this helped or if you have any questions
Old Dec 9, 2003 | 10:23 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
hey what rial do you grease up, pics of the rial, do you grease the outside rails or the rail with the steel briaded lines on it?
Old Dec 9, 2003 | 11:09 PM
ju5tchi11in's Avatar
roomate has a CL too
Mine just started to be REAL slow. especially my drivers side.
Old Dec 10, 2003 | 07:59 AM
nandowong's Avatar
I greased all of them. My passenger side is sooo slow so I just have the window lock on all the time so people wont mess with it. I really dont want to spend another 100 bucks on a new one.
also, you can grease the outside rail that you can see from outside the car. Is the groove where the glass attaches to the frame.
Old Sep 29, 2004 | 11:53 PM
nandowong's Avatar
bump for civicr4150
Old Sep 30, 2004 | 01:50 AM
99CL's Avatar
blah blah blah
good call nandowong. bump for civicr4150. Have he been PMing you as well? hahah
Old Sep 30, 2004 | 10:33 AM
joeshmoe's Avatar
My Home Planet
Good bump, but the pics don't work anymore.
Old Sep 30, 2004 | 11:01 AM
CLpower's Avatar
teh Senior Instigator
pics no work
Old Sep 30, 2004 | 11:25 AM
nandowong's Avatar
pics are here, on the bottom of the green cl pics
http://photos.yahoo.com/nandowong
Old Sep 30, 2004 | 05:00 PM
klepto's Avatar
you should redo the write up with pics :P
Old Sep 30, 2004 | 07:30 PM
99CL's Avatar
blah blah blah
It's not that hard to change out the reg. ONce you remove your door panel, you should be able to figure it out once you look at it.
Old Oct 1, 2004 | 04:32 PM
nandowong's Avatar
cycdaniel
Dec 17, 2019 10:58 AM
TLDude876
Dec 28, 2016 03:18 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
