Iacv
Iacv
I did a search and found out a little bit about the IAVC, and problems it can cause. I am experiencing these problems a little bit and want to take care of it ASAP. I know that the IACV is below the t/b and has a few lines running into it. What I dont know is how to clean it, and I couldnt find that in any preveous posts. Does it simply just need some oil squirted on it, or do I need to take it completely off and apart and clean it all out? Also, how hard of a job is this and what kind of bad results could I expect. Thanks for all the help!
A-CL Totaled Member
The pics are down, but heres a write up http://www.g2ic.com/forums/showthrea...highlight=iacv
Basically you can spray it with carb cleaner or brake cleaner.
cycdaniel
12-17-2019 10:58 AM
