Hub puller?
Old Apr 15, 2007 | 11:00 PM
hornedfrog2000's Avatar
B A N N E D
Hub puller?
Ok, I have been looking through old posts here and on honda tech for like 2 hours now. Do you need anything else besides a hub puller to do the front brakes, or is there some kind of machine that actually presses these things on? I saw a good DIY on there that looked like all you needed was a 30$ tool to pull the hub off the rotor. Thanks. Heres the link http://www.honda-tech.com/zerothread?id=1281812
Old Apr 15, 2007 | 11:21 PM
B A N N E D
I think I will just plan on having a pair of new wheel bearings, rotors, pads, and just hope for the best. If something goes wrong I have time, and I only seem to learn from the unexpected problems.
Old Apr 16, 2007 | 09:09 AM
Mach30SiR's Avatar
Bagel Bomber
this is a 97 right?
Old Apr 16, 2007 | 09:11 AM
saiko_cl_duck's Avatar
NOOB GUIDE FOR THE WIN!
That's if you are talking about the 97. You need to have them pressed on and off at a shop.
If you're not talking 97, then, well, yeah.
Old Apr 16, 2007 | 10:17 AM
B A N N E D
I am way beyond the noob guide on this one... I am asking if it would be possible for me to do it with just a hub puller like the one in the DIY. Yes its a 97, but the DIY looked pretty easy, but then everyone acts like its impossible and go dish out 400$... It looked like in the DIY the guy just used the puller to press them off, and then just pressed them back with a 2x4 and a mallet.
The only big issue it sounds like is when the hub is rusted to the bearing and you have to dig it all out.
Old Apr 16, 2007 | 10:39 AM
I'm sure it's possible, at least on "paper". But do you really want to be banging away with a 2x4 and a mallet on your brakes?
It seems like a long, tedious process on that job, totally not worth the time or effort, plus, how do you know they're on there correctly? Sorry, personally, it saves a good chunk of change, but is totally not worth it.
If the hub is rusted, yeah, good luck on that one, you'll have to chisel them out.
Old Apr 16, 2007 | 10:55 AM
B A N N E D
Did you see the diy I posted? It looks simple enough I think. It will probably take me a day to do it....I would hope no more then a day.
Old Apr 16, 2007 | 11:27 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
It's doable, other people on here have done the 97 brake swap without pressing the hub on, it is a pain in the ass from what I understand, god I can't wait to do the 98 hub swap
Old Apr 16, 2007 | 11:30 AM
yeah, I read it. I mean, hell, i'm not knocking it, just seems a little risky if you don't have any clue what you're doing. If you have the tools and the time, shit, go for it man. If it works, post back. Maybe you'll save some cash.
Old Apr 16, 2007 | 12:00 PM
B A N N E D
What does it cost to get the rotors/pads/wheel bearings installed? Depends on how much money it is. I know I could do it, but there would probably be some big issue I would have to deal with.
Old Apr 16, 2007 | 12:44 PM
(Mid-Atlantic)
My last 2 times just for labor, cost me between 250-300 per time Just for labor to do pads and rotors, which I provided, this is at 2 different shops
Old Apr 16, 2007 | 01:35 PM
Dicorp's Avatar
You are quite the optimist. My mechanic spent well over 6 hours removing the 4 bolts from the hub before he even began to press it out. It was so rusted. Take it to a mechanic, seriously and save yourself the headache.
Old Apr 16, 2007 | 01:39 PM
B A N N E D
Yeah, in the diy it shows those bolts and says to use an offset wrench thing... Or just take the axel out completely. I think the DIY is good because it lets you know what to expect. I'll do it myself and save myself 300$.
Old Apr 17, 2007 | 01:26 PM
civic_slayer's Avatar
You should be fine doing it yourself I have a 97 2.2cl and replaced the rotors with my dads help in an afternoon. we had a different kind of hub puller but the one mentioned in the DIY looks like it would be easier to use. and to press the hub back in we just tighten the lug nuts evenly and it worked fine.
Old Apr 17, 2007 | 02:46 PM
5-speed's Avatar
4x4- fat chicks cant jump
rotor over hub conversion FTW! Ive been wanting to replace my rotors/pads lately, but i also want to do the hub conversion.
Does anyone know where I can get 98 hubs and some wheel bearings for cheap?
sorry for the
by the way, thanks for bringing up that hub puller/diy frog. I might go this route if the hub conversion doesnt work out.
Old Apr 17, 2007 | 03:15 PM
shnee's Avatar
Land of Pleasant Living
it looks like you can do it fine with some time and muscle
is the 98 conversion considered easier or harder?
Old Apr 17, 2007 | 07:17 PM
B A N N E D
No problem, I will keep you guys updated to whether it was a good idea, or bad one. Either way it will get done soone here.
Old Apr 17, 2007 | 09:51 PM
(Mid-Atlantic)
Probably about the same, but it costs a good bit more
Jul 16, 2017 07:33 AM
LoneRonin
Jan 4, 2016 01:03 AM
neuronbob
Sep 19, 2015 10:45 AM
jmoney2001
Sep 11, 2015 12:07 PM
