How to tell when odometer was backed up?
Old Feb 27, 2003 | 07:06 PM
giugiaro_RENAMED's Avatar
I would like to know if their is a way to tell on first gen Cl 3.0 if the mileage was backed up. If anyone knows please let me know i got screwed on my last car i don't want it to happen again.
Old Feb 27, 2003 | 08:41 PM
showtz's Avatar
06 CGP TSX NAVI
The best way to tell is to run a car fax report. This will tell you about milage reports at emissions. Im not sure what the emissions laws report in Canada.
Other ways to tell are wear and tear on the car. If its got 50k and the drivers seats all cracked you should suspect something. Do you know how many miles the car has right now on the ODO?
Old Feb 27, 2003 | 09:56 PM
r3mix3r's Avatar
whoa whoa whoa...i got 55k miles and my seats are all cracked? my shits rollback?
Old Feb 27, 2003 | 10:05 PM
is their a way to check with the tranny or ecu? i thought u could check the mileage that way. I can be hard to tell by wear and tear somethimes between 120 000 kms (75k miles) or 220 000 kms (136 miles).
Old Feb 27, 2003 | 10:22 PM
melo72's Avatar
Who says that the odometer has to be rolled back? I know people that have instructions for turning off the odometer at the flick of a switch on a CL. All you need is the manual, the switch and a soldering kit.
Old Feb 27, 2003 | 10:36 PM
r3mix3r's Avatar
tell me ways to check other then wear...i seriously think mine is rolled back
Old Feb 27, 2003 | 10:54 PM
my girlfriends father had the dealer show him how to roll back the odometer. It was a chrystler, but thats still a scary thought.
Old Feb 27, 2003 | 11:01 PM
melo72's Avatar
Without actually showing you, all I can say is check to make sure that there aren't any cut wires underneath your dash, left side. Or switches connected to the wires that aren't factory.
Old Mar 2, 2003 | 02:22 PM
23's Avatar
23
You know you can also just pull one of the wire harness from the back of the gauge cluster and that would also do it.
Old Mar 3, 2003 | 12:21 PM
melo72's Avatar
The only problem with that is you lose the use of the other guages. Also, you would have to take the guage cluster out to do it. I'm talking about a switch that basically turns the guages on and off.
Old Mar 3, 2003 | 04:01 PM
-=DjPharmacy=-'s Avatar
A-CL CrAckHeAD
Has anybody done this successfully yet?
rockyboy
Aug 4, 2024 10:35 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
d.lim
Sep 15, 2015 08:54 PM
vbgregg
Sep 11, 2015 05:38 PM
