How to install gauges in a first gen?
Old Feb 8, 2005 | 08:44 PM
cl-baller201's Avatar
2.2CL owner
Hey Guys
Anyone know how to install gauges.....in a first gen CL '97
I just got my hands on a set, and I need to install them.
Old Feb 8, 2005 | 09:10 PM
cl_jay's Avatar
Registered
before someone gets pissed off and burns you, i will tell you nicely......
i remember there being a DIY on here on that just do a search and you should be good
Old Feb 8, 2005 | 09:26 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
take off the piece below the steering wheel column
there is 2 skrews holding in the trim around the guages that the dimmer for your lights is on, the screws should be on the top part so look up
then i think there is 4 screws holding in the guages the whole cluster if im not mistaken its beena while, you will need a skinny set of hands you will need to disconnect the harness from the back of the cluster and there are 3 of them and then all you do is disassemble the cluster and put the guages on
BUT BE VERY CAREFUL, with age the needles are VERY fragile so take it VERY slow
to power them up i wireed it to the power wire for the cluser and you can find this by finding or going to acura or someone on here for teh wiring scematics for the cluster wires or get a test light and test the wires to see when you touch it when the light comes on youve got power and then splice and there ya go
reassemble it and put it back in and enjoy
hope this helps
Joe
Old Feb 9, 2005 | 08:56 AM
2.2CL owner
so there are two screws holding the trim......so after you take both screws off
the trim should come out?
Old Feb 9, 2005 | 08:59 AM
Shaggz2Dope's Avatar
2.2 auto and coping
i wired mine into the dimmer switch...
there are two red wires use the one with the black stripe
silver reverse.....had em for 5 months
Old Feb 9, 2005 | 11:22 AM
shineynitelite's Avatar
NAWWWWSSSSSS
you gotta pull out the cruise control button with a little screw driver and the dimmer button and unplug them.. it wil be a lot more free after that (i did this last night, (avatar))...
Old Feb 9, 2005 | 08:21 PM
2.2CL owner
So let me get this straight, I take out the two screws ...that are located on top.
After that.....i take out the cruise control switch with a screwdriver. Then i take out the dimmer switch by hand. Then the plastic should pop out?
and then after that.....how do i install the gauges?
Old Feb 9, 2005 | 08:43 PM
2.2 auto and coping
remove all the black screws already on the gauges
the gauges should overlay the stock..bend them so the can slide ..be extra careful with the needles...im serious..
remove the 3 or 4 lights in the back....wont be able to see them with your new gauges....they should have a blue rubber cap on them....they are 194 or so
then feed the all the wires out of the back using the new holes
leave the ones on the top so you can see your odometer
like this genius said....
since i did that...i can dim the odometer as much as i want and also ajust the brightness of the gauges separately
Old Feb 9, 2005 | 09:11 PM
2.2 auto and coping
one more thing...the black wire into the black one on the dimmer switch
Old Feb 9, 2005 | 10:21 PM
NAWWWWSSSSSS
get a really small flat head screwdirver there are little tabs on the dimmer/cruisecontrol on the bottom.. then you'l have to reach for the clips to unplug them and it will loosen the black piece greatly
Old Feb 12, 2005 | 11:56 PM
ruin's Avatar
Hey Guys
looks like u got instructions already beware of the needles
Old Feb 13, 2005 | 11:10 AM
wilp99's Avatar
and be careful of the plexiglass when trying to remove the cluster from the dash. i broke mine and was irate. costed me another 35$ from acura.
Old Feb 14, 2005 | 04:35 PM
2.2CL owner
Yea iam gonna try to install them sometime this week.
Lets see how they come out
Old Mar 14, 2005 | 06:12 PM
griff43081's Avatar
Rebuilder
Ok ... i installed my guages but now i have the two wiresleft to hook up. red and black for the power to light them. The instructions i have say to tie them to the headlight power wire and the ground. problem is i have no idea where/what the headlight power wire is.
i cant run it to the dimmer b/c thats broke in my car.
so how can i get power?? Its already dark out and i'm driving blind .. sort of
Old Mar 15, 2005 | 01:41 PM
griff43081's Avatar
Rebuilder
anyone?
Old Mar 15, 2005 | 01:51 PM
legendaryCL98's Avatar
'07 November = STI
Originally Posted by griff43081
anyone?
splice the dimmer switch for power
dont snip the wire, just peel off the coating on the +/- wires for the dimmer switch and either T-tap them together or use electric tape
Old Mar 15, 2005 | 01:53 PM
'07 November = STI
there is a screw behind the dimmer switch
and there is a screw behind the cruise control
take those out and the plastic should come off
Old Mar 15, 2005 | 02:25 PM
griff43081's Avatar
Rebuilder
ha .. i spent over an hour before i found those screws. good thing i didnt just pull har .. damn piece is $60!!
Old Jun 8, 2005 | 07:12 PM
2.2CL owner
can anyone be more cleare with these instructions?
I still dont know how to install the gauges
anyone?
Old Jun 8, 2005 | 07:22 PM
'07 November = STI
anyone?
come to seattle, ill do it for free
hehe
Old Jun 8, 2005 | 07:24 PM
ajtcl's Avatar
Peace, Love & Acura
There really is a thread on this... Also, why not get another dimmer so you can adjust the brightness.
Old Jun 8, 2005 | 07:57 PM
wilp99's Avatar
the guages i have came with a dimmer knob and a blue or green color switch.. in fact im bout to take them out prolly tomorrow, so if anyone wants them ill hook u up w/ a good price..never had a problem with mine.. bout 1 year now,
http://pg.photos.yahoo.com/ph/wilp99...c8.jpg&.src=ph
http://pg.photos.yahoo.com/ph/wilp99...3f.jpg&.src=ph
http://pg.photos.yahoo.com/ph/wilp99...d5.jpg&.src=ph
i got the switches mounted into the left coin holder which i never used.. damn after lookin at the pics its been over a year..
Old Jun 8, 2005 | 08:01 PM
ajtcl's Avatar
Peace, Love & Acura
Are you going stock?
Old Jun 8, 2005 | 09:29 PM
2.2CL owner
why are you takin' them out
you dont like the white gauge look during the day?
cuz Iam not feelin' the white look too much
but you gotta have that knob stickin' out there?
Old Jun 10, 2005 | 01:25 AM
wilp99's Avatar
i only put it there cause anywhere else would be expensive as hell if i wanted to remove it, or would look ghody.. its kind of discreete where it is. besides when i get my 15" L7's ill need somewhere to mount my amp knob.
but yea im kind of tired of the white faced guages look. i had to turn them all the way down to where they are barley glowing to get any kind of a they came stock with the car look. i think im gonna go with the black light up top thing.. itll make the needles glow a nice bright orange, and the numbers light up all crazy. someone else here on this board has done it, and i thought it looked tight.
Old Jun 10, 2005 | 03:56 PM
2.2CL owner
[QUOTE=wilp99]i only put it there cause anywhere else would be expensive as hell if i wanted to remove it, or would look ghody.. its kind of discreete where it is. besides when i get my 15" L7's ill need somewhere to mount my amp knob.
yea man.....the white face look .....reminds me of a 99 Maxima...for some reason
Iam just not feelin' it...........anyone wanna buy some white face gauges?
I bought them off VXCL..........20 bucks......Jrzy...NYC area
Old Jul 24, 2005 | 02:24 AM
Blazn5's Avatar
Please. Let me know where you can get the gauges with the black light. That would be sick.
BoricuaTL
Apr 8, 2016 01:08 PM
Frathora
Sep 28, 2015 11:29 PM
brandnewcolony
Sep 12, 2015 10:39 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Nicho863
Sep 2, 2015 08:12 AM
