hopefully this has happen'd to somebody else
Old Apr 5, 2005 | 05:58 PM
shineynitelite's Avatar
NAWWWWSSSSSS
there is a bolt that goes through what seems to be a lower control arm (that holds the rear strut in place) the bolt that goes through one side of the strut then through the bushing and out the side with teh nut (on the strut) broke off.. i cut off the bolt side so now the only thing holding it in is the bolt still inside the bushing..
is that bushing threaded?
where can i get one faster than 3-4 day shipping (from acura) 28.99 each..
the other side is just as hard to get off i think its going to break tooo what gives????
Old Apr 5, 2005 | 06:31 PM
azian21485's Avatar
7-30-05 First Place STS!
only threaded part is a bolt that is welded onto the shock body....nothing else is threaded but that part
you can go get a bolt from any hardware store for a temporary fix until you can find an oem bolt....i wouldn't trust a low grade bolt from a hardware store but you can't really do much about it i guess
local junkyard is also a easy place to nab bolts
when you install new bolts using anti-seize will prevent future headaches...goodluck
Old Apr 5, 2005 | 06:56 PM
NAWWWWSSSSSS
thanks.. i have 2 oem bolts coming in tomorrow from teh acura dealership... i just gotta get the old one out!!
i wanna get it out tonight so that i can get the new strut and spring ready to go in.. (so all i will need is the new bolts..)
Old Apr 5, 2005 | 07:08 PM
NAWWWWSSSSSS
i just hope a punch + hammer will get it out
Old Apr 5, 2005 | 08:54 PM
Motohip's Avatar
I'm a llama :(
No, don't punch it out with a hammer. They sell stuff to remove bolts with broken off heads. It's like a reverse drill bit I think and you just drill it in and take it out. Damn, I guess I was lucky nothing like this happened to me.
Old Apr 5, 2005 | 09:10 PM
agranado's Avatar
how handsome I am
hey shannon what've you been driving in the meantime?
-Alex
Old Apr 5, 2005 | 11:24 PM
wilp99's Avatar
its called an ez out. u drill a small hole in the top where the head used to be, then tap the ez out in to the hole and use a wrench to unscrew the ezout bit. thier not too expensive, maybee 15$
Old Apr 6, 2005 | 01:51 AM
NAWWWWSSSSSS
but the bolt cant be screwed out it has to be pulled out... it has lateral grooves so that it cant be spun!!! rememeber!!! its for sure stuck in their i'm going to try some heavy duty power tools tomorrow i jus twant this shit to end
Old Apr 6, 2005 | 01:52 AM
NAWWWWSSSSSS
-Alex
my dad and i have a 03 chev impala that i drive all the time.. that and i will be taking my bike out of storage tomorrow hopefully!!..
Old Apr 6, 2005 | 07:11 AM
pebe's Avatar
Wow, this does seem to happen to everyone. Happened to me, twice. Bring it to a shop to get it out.
Old Apr 6, 2005 | 08:10 AM
DivineCL's Avatar
Revelation 3:15-17
Next time, let a trained professional install the shocks for you.
It isn't worth the headache. Not to mention that you're spending
money on parts you've broken which in the end will equal to
what I spent, to have them installed at a local shop.
Old Apr 6, 2005 | 08:16 AM
azian21485's Avatar
drill > any bolt
Old Apr 6, 2005 | 08:21 AM
CL Platano's Avatar
Tristate ViP Crew
I watched as they did mine and they did the punch and hammer to get it out..I looked at them like WTF are you doing but they tried all air tools and that biatch wouldnt come out for nothing. Oh yeah nice Avatar
Old Apr 6, 2005 | 10:26 AM
haiduc's Avatar
Moderator Alumnus
that sucks. the bolt is most likely stuck. A hammer might might not do the trick.
When I had this problem, a torch and hammer fixed the problem. If you heat up the bushing sufficinetly, it will just melt the plastic. Then, you can hit it and it comes out.
I think I posted a theread about that crappy experience.
edit: here you go.
https://acurazine.com/forums/showthr...highlight=rear
Old Apr 6, 2005 | 11:14 AM
Randol's Avatar
I went to a shop and the same thing happend there so it is just a flaw with our cars. You will probably have to replace that bushing. It will need to pressed in by a machine shop. Save your self the time of trying to punch it out you will just damage the bushing anyway and end up replacing it so just do it now it will save you time but not $$$.
Old Apr 6, 2005 | 11:20 AM
deepestbluest84's Avatar
happened to me, i took the easy way out, went to pepboys, got a exact screw, screwed it in and i was good. jus was a hassle cuz i had to find the screw. other than that no problems so far
Old Apr 6, 2005 | 11:36 AM
NAWWWWSSSSSS
well shit i have the strut out and nothings going to hold it in place anyway cuz half the bolt was snapped in on the inside!!! the car is NOT leaving the garage
Old Apr 6, 2005 | 01:15 PM
Motohip's Avatar
I'm a llama :(
It's threaded at the end of the bolt. Those lateral grooves aren't anything. Won't you screw up the threads if you hammer it out? Everyone keeps talking about bushings...There was no bushings holding the rear strut in place.
Old Apr 6, 2005 | 01:27 PM
NAWWWWSSSSSS
the bolt goes through the strut and through the bushing (inside of the lower control arm)
Old Apr 6, 2005 | 01:28 PM
Shaggz2Dope's Avatar
2.2 auto and coping
looks like you got peanut butter on your steering wheel
Old Apr 6, 2005 | 02:53 PM
VXCL's Avatar
AWD Torque Monster
i just torched out the rear bushings and called it a day. then had to wait a week for new ones. super easy if it wasnt for the wait.
Old Apr 6, 2005 | 03:19 PM
NAWWWWSSSSSS
3 days for new bushings.. i got the bolts already
update:
car is at my buddies shop.. they are going to finish it for me
Old Apr 6, 2005 | 03:20 PM
NAWWWWSSSSSS
sure do
Old Apr 6, 2005 | 03:44 PM
pebe's Avatar
I went 2 days without my car the first time I changed the springs. Freakin sucks.
Old Apr 8, 2005 | 08:35 AM
NAWWWWSSSSSS
i'm going on a week...
everybody cheer me on in getting my car back today cuz if i do there will be some serious photoshoot action with other acuras
Old Apr 8, 2005 | 08:41 AM
VXCL's Avatar
AWD Torque Monster
shiney i just realized there's a bird on your steering wheel. i got conures myself. anyways hope you get your car back. i been there and the wait sux.
Old Apr 8, 2005 | 09:21 AM
agranado's Avatar
how handsome I am
these'd better be some awesome photos.
and congrats on finally getting your car back - I know now exactly what NOT to do when I go ahead and by my new suspension
-Alex
Old Apr 8, 2005 | 10:31 AM
Motohip's Avatar
I'm a llama :(
Oh, and uh...
Old Apr 10, 2005 | 03:59 PM
NAWWWWSSSSSS
update:
still dont have the car back
STORY: its bobs shop.. i called bob before i brought it their and he siad it was going to be 202.00 which i wasnt happy about anyway... i said ok and brought it over there....
there is a guy that does work at the shop on the weekend.. and he agreed to do it so that i could take it out and roll it on saturday night ----> this guy calls me at like 10 last night and told me that it was done and i could come get it.. he continues to talk and says your total is 398.48
i was silent then i said, "NO, its 202"
he told then me that he gave me that quote before they knew i needed new bushings etc which was COMPLETE BULLSHIT becuase if i wasnt for the bushigns i wouldnt have brought it in there, and finished it myself!!!!!!
i have to wait till tomorrow when the owner comes in... SO
cars done but not in my garage yet..
Old Apr 11, 2005 | 12:38 AM
h2o-pr00f's Avatar
Im No Superman
not a joke at all similar shit happend to me.. the bolts thal go through the control arm and the shock.. the heads to em flew off.. things got jacked up to the point my mechanic had to get new parts n stuff.. the whole thing was a huge mess im so glad i didnt do it myself good luck shiney, only took me a day tho those guys rushed on getting stuff replaced.. drove to north holywood to get me new control arms n such
edit: cost me another $300 to get shit fixed on mine
Old Apr 11, 2005 | 12:40 AM
NAWWWWSSSSSS
tell me about it.. worst case scenario
Old Apr 11, 2005 | 01:06 AM
agranado's Avatar
how handsome I am
fuck mother fuck burn those FUCKERS
NAWWWWSSSSSS
will do
Old Apr 11, 2005 | 11:24 AM
CL Platano's Avatar
Tristate ViP Crew
I hate mechanics that don't use common sense..He should not have continued until he had your approval to put in new bushings. They can't put in new parts without your consent and then charge you for them. If anything you can sue them.
SidhuSaaB
May 30, 2020 12:40 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
