audio
Old Apr 9, 2005 | 07:34 PM
$peed])emon's Avatar
Si says "shut the fuk up"
audio
will this set up work???
rockford p4004 amp max power= 1200 watts max and
2 12" infinity subs = 1200 watts each
Old Apr 9, 2005 | 08:07 PM
endlessdragon's Avatar
~ The Endless One ~
why not?
Old Apr 9, 2005 | 09:40 PM
wont the subs be under powered cuz there is 2 subs that are 1200watts and the amp it self is 1200 watts?
Old Apr 10, 2005 | 12:12 AM
froggystyle14's Avatar
"FROGGYSTYLE"
the amp is probably 1200 watts max at 4 ohms, if you drop it down to a 1/2 ohm, then you probably would be pushing around 1900 watts. i would buy it
Old Apr 10, 2005 | 01:33 AM
uncald4's Avatar
Former Sponsor
Great place to ask a question. Now you'll get 50 uneducated answers from people that think they know. If you are serious you should go to a reputable car audio shop and ask them.
Huge diff between somebody that's done it once or twice. And someone that does it for a living.
Old Apr 10, 2005 | 03:32 AM
what does that mean??? im asking cuz i was gonna buy this stuff off someone and do everything myself?
so unclad, what do u suggest???
Old Apr 10, 2005 | 12:03 PM
uncald4's Avatar
Former Sponsor
Im suggesting that if you want the right answer, go to a car audio shop. A good one. If it's important that you have it done correctly.
Old Apr 10, 2005 | 12:22 PM
klepto's Avatar
would that kind of amp even be stable at 1/2 ohm?
Old Apr 10, 2005 | 12:34 PM
aRIff's Avatar
Ottoman Empire
use your p4004 for front and rear speakers. Go and buy a P6001 mono for your subs. You can control them very well with this amp + use less power to run it.
Old Apr 10, 2005 | 08:59 PM
so i should get 2 amps??? i was planning on goin to futureshop to buy some shit......
Old Apr 10, 2005 | 09:59 PM
Andrewmc621's Avatar
the p4004 only runs about 50X4 rms(not exactly sure, didnt check it) , and max wattage doesnt really matter. its designed for speakers, not for subs. you would be better off with a 2-channel or a mono amp to run the subs.
Old Apr 10, 2005 | 10:08 PM
how many watts should the amp have if i got 2 12" with 1200 watts each??
Old Apr 10, 2005 | 10:41 PM
Nick 97cl's Avatar
Or at least make a phone call....I'm sure they wouldn't have a problem telling you. Don't ruin a bunch of expensive equipment just because someone says it'll work, especially when you can get the facts for free..
Old Apr 11, 2005 | 01:32 AM
uncald4's Avatar
Former Sponsor
Old Apr 11, 2005 | 12:07 PM
golfindude's Avatar
I'll do just one!
Any 4 channel amp is used mainly for highs since you will be putting 2 sets of speakers to it. You can bridge everything if you are good wiht wiring. But for your subs i would go with a one or two channel amp, it will save you lots of power and not blow your amp. I also wouldn't put any amp under 2 ohms. My friend tried to do it and blew a whole bunch of fuses. It is way to much power.
But if you want to drop the ohms go to a car audio place inb your area and ask them to instal it. I know at my local Mobil one they install bass amps for about 40 -50.
Old Apr 11, 2005 | 12:16 PM
dragon084's Avatar
1999 CL3.0
off topic / audio-video
ull get more of a response over there
Old Apr 11, 2005 | 01:13 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
