hooking up a system
Old Jun 2, 2006 | 01:12 AM
chinoscl's Avatar
hooking up a system
Does anyone know the easiest way to run a power wire for an amp to the fuse box?
Old Jun 2, 2006 | 02:03 AM
subbuzz's Avatar
07 tl-s in
do you mean the batt
Old Jun 2, 2006 | 02:29 AM
natesezgoblue's Avatar
fuse box??
run power wire up the drivers side of the car(rca's up passenger side, through the grommet by the fuse and to the battery.
just pull up step panels( panels below the door) and push the wire down, run next to the seat and to the trunk..its pretty easy plus that panel pops right off..
Old Jun 2, 2006 | 06:31 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I ran mine behind the fuse box, and into the rubber grommet that goes into the firewall, then just route it up and over your strut to your battery. Note: that's for 3.0 - 2.2 the battery is on the other side
Old Jun 2, 2006 | 08:21 AM
acuratl_2nr's Avatar
On the 2.2 you can run your power wire on the passenger side. You have to get the under-hood fusebox out of the way in order to see the grommet
Old Jun 2, 2006 | 09:44 AM
rajin_2.3cl's Avatar
trini to de bone !
would 1/0 awg power wire fit through that grommet on the 2.X CL's ?
Old Jun 2, 2006 | 09:55 AM
Slooo97CL's Avatar
who cares drill through the firewall
Old Jun 2, 2006 | 10:11 AM
(Mid-Atlantic)
Don't do that, it'll fit, it just pops out
Old Jun 2, 2006 | 10:31 AM
arstraub's Avatar
ur as welcome as cancer
That's what I did; works just fine - but that's in a 3.0; might be different in a 2.2
Old Jun 2, 2006 | 11:26 AM
TurboMike's Avatar
My other car is a DSM
Theres nothing wrong with drilling a hole in the firewall, as long as you use something as a grommet to protect the wire from the cut metal. Unless you buy the wiring by the foot, most amp wiring kits will come with a grommet that fits the wire perfectly.
Old Jun 2, 2006 | 11:28 AM
chinoscl's Avatar
well i think im hookin the remote wire to the bolt to the fuse box
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
AcuraKidd
Sep 25, 2015 11:18 PM
