hooking up a system
Originally Posted by chinoscl
Does anyone know the easiest way to run a power wire for an amp to the fuse box?
fuse box??
run power wire up the drivers side of the car(rca's up passenger side, through the grommet by the fuse and to the battery.
just pull up step panels( panels below the door) and push the wire down, run next to the seat and to the trunk..its pretty easy plus that panel pops right off..
I ran mine behind the fuse box, and into the rubber grommet that goes into the firewall, then just route it up and over your strut to your battery. Note: that's for 3.0 - 2.2 the battery is on the other side
Theres nothing wrong with drilling a hole in the firewall, as long as you use something as a grommet to protect the wire from the cut metal. Unless you buy the wiring by the foot, most amp wiring kits will come with a grommet that fits the wire perfectly.
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
AcuraKidd
Sep 25, 2015 11:18 PM
Don't do that, it'll fit, it just pops out
