Help - Lights arent Lighting
Could you help me out. My Dashboard Lights and Parking Lights dont come on, I looked at the fuses and they are fine. My headlights, break lights and dome light still have juice. Is this the Lighting Relay? I have a 2.2.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sounds like a bad relay. Did you check the internal fuse box and the external fuse box? I believe there are 2 different fuses, just a thought.
Fuse Box
Yeah I checked both fuse boxes and both fuses were good. I did instal a sirius unit and hardwired power to the back of the cigarette lighter and grounded it through the ground through the back of the head unit. I am gonna pull it out and see if things return to normal.....
(Mid-Atlantic)
(Mid-Atlantic)
The cigarette lighter is on the radio fuse, does your radio still work? The lights wouldn't be affected unless you tapped off the blue/green bulb for the cig lighter.
Hmm...
The thing is that i DID tap off of the white wire with the blue/teal stripe that way the unit comes on only when i turn the key. Is this not cool? I just disconnected power to the sirius reciever and still no lights. I do appreciate your help. Does the relay work with only these features that are dead?
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
