AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   1G CL (1997-1999) (https://acurazine.com/forums/1g-cl-1997-1999-56/)
-   -   Help - Lights arent Lighting (https://acurazine.com/forums/1g-cl-1997-1999-56/help-lights-arent-lighting-475773/)
rosco4eva 01-06-2006 08:15 AM
Could you help me out. My Dashboard Lights and Parking Lights dont come on, I looked at the fuses and they are fine. My headlights, break lights and dome light still have juice. Is this the Lighting Relay? I have a 2.2.
97BlackAckCL 01-06-2006 08:35 AM
Sounds like a bad relay. Did you check the internal fuse box and the external fuse box? I believe there are 2 different fuses, just a thought.
rosco4eva 01-06-2006 10:11 AM
Fuse Box
Yeah I checked both fuse boxes and both fuses were good. I did instal a sirius unit and hardwired power to the back of the cigarette lighter and grounded it through the ground through the back of the head unit. I am gonna pull it out and see if things return to normal.....
97BlackAckCL 01-06-2006 10:22 AM
The cigarette lighter is on the radio fuse, does your radio still work? The lights wouldn't be affected unless you tapped off the blue/green bulb for the cig lighter. :shrug:
rosco4eva 01-06-2006 11:35 AM
Hmm...
The thing is that i DID tap off of the white wire with the blue/teal stripe that way the unit comes on only when i turn the key. Is this not cool? I just disconnected power to the sirius reciever and still no lights. I do appreciate your help. Does the relay work with only these features that are dead?
