Help with lights
Old May 29, 2004 | 03:02 PM
Blacura's Avatar
-iii-(
Help with lights
i'm converting my car back to stock to sell, so i'm taking out the HIDs and putting the halogens back in.
I spliced the 9006 connectors back in and turned on the lights and this happened:
Drivers side: Low beam dim, high beam dim
Pass. side: Low beam regular brightness, high beam dim
any suggestions??
Old May 29, 2004 | 03:05 PM
klepto's Avatar
suggestions: sell me the hid's
Old May 29, 2004 | 03:06 PM
Blacura's Avatar
-iii-(
hah, but seriously i need to get this figured out.
Old May 29, 2004 | 06:09 PM
jakelovescake's Avatar
Payer of high insurance
are you selling all your mods cause if so i would be intrested in the short shifter
Old May 29, 2004 | 11:36 PM
uiskibum's Avatar
its paid for
check your ground. that has been the cause of many problems for me
Old May 29, 2004 | 11:38 PM
Blacura's Avatar
-iii-(
skibum, how do i go about that?
it seemed to be fine with my hids
Old May 29, 2004 | 11:41 PM
liloj's Avatar
i like orange juice
your best bet would to replace your harness w/ a new one....did you orginally cut off the factory one? or just tap into the wires?
Old May 30, 2004 | 12:56 AM
Blacura's Avatar
-iii-(
i cut off the original and i bought 2 new ones. the passenger one works, the driver's side one is jacked up for some reason. I dont even know if it's the harness that's messed up.
Old May 30, 2004 | 01:03 AM
liloj's Avatar
i like orange juice
it could just be the harness..if you have a current tester...you could test to make sure its getting the proper voltage..i dont know what voltage u should be getting..but that would be the best thing to do is test the current, if your getting current then the wiring is good, coul be the bulbs, if your getting a low or no current, then the wiring is bad...only way to know for sure
Old May 30, 2004 | 02:56 AM
Blacura's Avatar
-iii-(
My dad has a voltmeter, i'll compare the left lowbeam voltage with the right tomorrow. Thanks, hope it works!! I can't drive at night yet! :o
Old May 30, 2004 | 04:32 AM
liloj's Avatar
i like orange juice
if that dont help, then i really dont know what else to do
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
