Headunit and remote start??
Old Sep 28, 2006 | 04:18 PM
malice's Avatar
Hey guys,
2 things, when I remove the stock headunit and install the aftermarket deck, should I remove any of the fuses to prevent blowing any, and if so which fuse should I remove?
Second, I have an Astrostart (astroflex) remote starter, how the heck do i use it and have my defrost come on at the same time? Someone said just turn on the defrost before I just the car off, but because the defrost, heat, a/c is all digitilized I believe it shuts off automatically when you turn the car off, it's not like turning a knob for your defrost and leaving it on...any idea's how to get the remote start and defrost to work on start up?
Old Sep 28, 2006 | 04:31 PM
STL+3.0CL's Avatar
Matt
Your correct, the button is not a "press" and "depress" button like the seat warmers.
Your not going to be able to turn the defrost on unfortunately. Unless you create some sort of crazy robotic arm that will push it for you in the morning.
Old Sep 28, 2006 | 06:51 PM
.:bob schmo:.'s Avatar
'97 Black 2.2CL
Actually (this goes for 97's at least) if you have the front defroster on before you turn off the car, it will turn back on when you start up again--just like the temperature and fan settings remain the same. However, this will not work for the rear defroster...hope this helps!
Old Sep 28, 2006 | 07:10 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
As for the fuses, no just make sure the car is off and keys are out
Old Sep 29, 2006 | 07:52 AM
Mach30SiR's Avatar
Bagel Bomber
is there any remote starts that will work with our OEM alarms ?
Old Sep 29, 2006 | 08:28 AM
(Mid-Atlantic)
Lots
Old Sep 29, 2006 | 02:21 PM
Mach30SiR's Avatar
Bagel Bomber
links! so these units can be put in our CL's and use the OEM alarm fob?
Old Sep 29, 2006 | 02:30 PM
(Mid-Atlantic)
U wanna use the factory alarm right? That's easy, just get an add on remote starter with option for a chip
Old Sep 29, 2006 | 03:31 PM
Mach30SiR's Avatar
Bagel Bomber
can you supply me with some suggested links - pimp
Old Oct 1, 2006 | 07:29 AM
Mach30SiR's Avatar
Bagel Bomber
common black ack whacha got for me?!?!? i might have a picture of the key hold LED around here somewhere to trade ya hah
Old Oct 2, 2006 | 08:29 AM
Mach30SiR's Avatar
Bagel Bomber
where you at pimp of the burg??????? yeah blackack you should be doing your morning whore rounds right now.
Old Oct 2, 2006 | 08:54 AM
(Mid-Atlantic)
Pimp of the burgh, yeah that's me. Morning whoring easy there
I don't have a specific remote start to name, since I have a viper alarm with remote start. Do you have a 97, or 98-99. The RS would be different for the 2 sets of years. Let's start there. And I def want pics of the keyhole AND climate control, you ever get that one done? I'll help you find one
For future reference, I don't check all the threads on here, PM works too
Old Oct 2, 2006 | 09:34 AM
Mach30SiR's Avatar
Bagel Bomber
I'll see if i can snag a picture of the key hold - its nice but i haven't started on the climate control yet.
i have a 98 3.0 I'd love to keep the stock remote but add autostart function if thats even possible.
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
