Has anyone used the Eibach Pro Kit?
I am about to lower my CL and I was going to use the Eibach Pro Kit because it claims there are no camber adjustments needed, however I have seen some claims in this forum that contradict that. Is there anyone who has installed this kit that can give me some feedback? If I have to spend the $$$ on camber adjustments I will go with more than a 1.4" drop.
yeah depends on the shocks. i used koni yellows set on the lower perch and it dropped the car another .5" about. and it seems i might need a camber kit if there is not enough play to adj when i get an alignment. if i left it on the default perch i couldnt imagine a camber kit being needed.
even with prokits u will more than like blow ur stock shocks. the spring rate of the springs will have them working harder than ever and ur shocks are at least 4 years old. either they blow or u get lucky. and if they do u will have to pay to get ur springs taken off and new shocks put back in with ur springs. at least $150 - $200labor
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
