Grounding Wires Question
Originally Posted by 972xghost
im thinking about getting ground wires from Sun Auto and replacing my stock ones. but my question is what stock wires do i have to replace.
i thought the kits usually come w/instructions
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by ayougo
on our cars, they dont do shit. but they look nice if you do it right !!!!!!11
I got them in my car. Just throw them in there. Connect them from the alternator to the firewall over by the fuse box (well that's how it is on our 3.0), and then connect it to your battery terminal to the firewall and another to the head or block. Just ground them and you'll be fine. But I didn't notice anything though.
Originally Posted by shineynitelite
it gives you a little hp gain, gas mileage bust most of all its improves your idle a shit load (prolly not really detected unless you have a vafc2)
another minor mod i was told to look into was a breather filter by my valve cover. i was "told" that that hose that leads from my valve cover into my intake sends oil residue into my intake, idk if that makes sense or not but im told that the breather filter will help my engine run better. i just thought those things were for show, i didnt no they had a person.
that breather will just make a mess all over the place.. you can get an oil catch can that will filter out hte oil vapors and send clean air back into the intake., but you have to drain it everytime you change your oil or you will suck in straight oil.
if your going to do it get two breathers. one for the intake pipe and one for the valve cover. remember it will make a mess. so keep an eye on it. it sucks oil vapors back in to releave the blow by pressure in the cylinder head. it cant just dump oil on the ground so it sucks it back up into the intake to burn off the oil vapors.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
