Grounding Kit for the 3.0
does anyone have one, or use one?
I don't think they make one particularly for our car, but I found a universal one that APEX makes, what do you think?
http://www.nolimitmotorsport.com/Mer...Category_Code=
i used a custom one that i made from 4g wire...you not gonna gain much power (although the hyper ground showed 10 whp on an integra
) but it helped if you need a stronger electrical system, i noticed the idle improved a lot and the headlights seemed a tad brighter, and no dimming from the lights when you rolled down the windows, or pushed the button when the were up, etc....
and $196 for a ground kit! thats to much.... http://www.optauto.com/webstore/prod...4491&last=4491 better prices here
grounds are good, you dont want potential difference between any of the things that electrical parts are grounded to... so esssentially you tie together a lot of grounded items and teh neg post of the battery. ive seen grounds on block, tb, alt, intake (if its aftermarket), strut tower, firewall, neg post, transmission, and then one or two other points on the frame of the car.
very easy diy and can help a lot on some cars.
It's better to just upgrade the factory grounds. These kits have long lines of questionable quality wire. The high EGR will do more harm than good.
This horse has been beaten so many times, there is a f^cking stain on the carpet - SEARCH!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
go buy some 4g wire and the connectors a shitload cheaper, thats how i did mine for less than $40...
