Front Grill
Old Dec 28, 2001 | 11:04 PM
gmb2000's Avatar
Front Grill
I have a 99 CL. I got a 97 CL grill I want to put on my 99 CL.
Will I be able to put this grill on my 99 with out any problems?
Do I need clips to put the chrome section on? HELP
Old Dec 29, 2001 | 09:58 AM
dustbuster4's Avatar
A-CL Post Whore w/N2O
I've not done this (put a '97 grill on a '99 CL). But when I replaced my '97 grill with a '97 gold kit (plus a new plastic grill), the installation went smooth! I just used all of the screws and nuts from the original grill to install the replacement grill.
Did you buy the black plastic grill in addition to the chrome pieces (logo/wings and trim ring)? I ask this because the '97 chrome pieces won't fit on the '99 black plastic grill.
Let me know if I can help.
Old Dec 29, 2001 | 11:13 AM
1StGenCL's Avatar
958 & 991
It should fit in fine. Just remove the four screw things to remove the whole grill and put the new ones in.
Old Dec 29, 2001 | 04:21 PM
Casper98CL's Avatar
You Fawkin Kiddin Me!
yea the 98 grill is one piece, chrome and black together... its probably the same for 97 & 99.... 4 screws and i think to snap on clips.... in and out!
Old Dec 29, 2001 | 04:36 PM
haiduc's Avatar
Moderator Alumnus
i've done it more times than i care to remember... the grilles are a perfect swap between eachother. all the bolts line up.
Old Dec 29, 2001 | 05:42 PM
gmb2000's Avatar
what screws in the chrome ?
Old Dec 29, 2001 | 06:29 PM
gmb2000's Avatar
how the hell do you take off the 2 plastic clips on the inside off the grill
Old Dec 29, 2001 | 06:59 PM
Casper98CL's Avatar
the chrome is molded with the black center... use a flat screw driver to pinch the clip... squeezes right out!
Old Dec 29, 2001 | 07:20 PM
gmb2000's Avatar
ok got the 99 grill off now. what hardware do i need for the 97 grill?
Old Dec 29, 2001 | 07:22 PM
Casper98CL's Avatar
NONE.. snap it back in and screw it with the same screws!
Old Dec 29, 2001 | 07:27 PM
gmb2000's Avatar
how do i get those black plastic clips off the 99 grill. I do need them for the 97 correct?
Old Dec 29, 2001 | 07:33 PM
Casper98CL's Avatar
ok hold on... do you have the 97 grille??? it should be the same... the black clips on my grille were molded off the grille (one piece with the grille) I am assuming that both of your grilles follow the same format... If you have the 99 grille out.. slap the 97 grille in... it should have the clips molded in it... snap it in and screw it on!!!
Old Dec 29, 2001 | 07:35 PM
gmb2000's Avatar
it does not have those clips in them
Old Dec 29, 2001 | 10:12 PM
1StGenCL's Avatar
958 & 991
Hey do you want to sell your '99 grill?
Old Dec 29, 2001 | 10:14 PM
gmb2000's Avatar
I broke a clip on my 99 grill
Old Dec 29, 2001 | 10:17 PM
1StGenCL's Avatar
958 & 991
Does that mean it wont stay in at all or what?
Old Dec 29, 2001 | 10:18 PM
gmb2000's Avatar
Only one of the clips is broken. I dont know if it will stay on or what
Old Dec 30, 2001 | 12:25 PM
Casper98CL's Avatar
bro you'll be fine with it... it also stays in with 4 screws!!
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Sep 17, 2015 10:16 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
08 NBP TL
Sep 8, 2015 08:49 PM
