Engine Replacement
Old Nov 1, 2001 | 10:17 PM
1stGen_CL2001's Avatar
6th Gear
Engine Replacement
Am i right in believing that if you replace the stock engine on our cars and the car is an automatic, if you put in a Japanese engine will it turn it into a 5 spd. because i keep hearing, "if you get this engine you get --hp plus the 5spd. whats this mean! please help?!?
thanks.
Old Nov 1, 2001 | 10:34 PM
CLUofI's Avatar
337
if you are asking what 5sp means. It is a 5 speed manual (stick)
Old Nov 1, 2001 | 10:41 PM
6th Gear
engine replacement
I wasn't asking what 5spd means, i was asking if you replace your engine does it turn your automatic into a stick? because people are saying "you get the 5spd" shouldn't they already have one?
Old Nov 1, 2001 | 11:39 PM
f0de's Avatar
Ham Sandwich
you can get a manual trans.. you need to get a manual center console for the shifter so it has room.. or just cut your center console into a big square.. and you need to hang a clutch.. its work so don't think your just going to drop a new engine in and magically have a 5spd
Old Nov 2, 2001 | 10:55 PM
6th Gear
So am i going to have to replace the transmission and the engine or can i keep the stock transmission. Or can i just replace the transmission for a stick and put a turbo in. Does anyone know how much this will cost me for installation? Or even how much new transmissions cost if all i have to do is replace that to get the 5spd?
Old Nov 2, 2001 | 11:47 PM
1StGenCL's Avatar
958 & 991
Well you cant just replace the engine and expect your auto to change to manual so yes you would have to replace your transmission as well. As far as changing your auto to a manual it probably isnt worth all the money it would cost. Im not even sure you can do it on the 3.0
Old Nov 3, 2001 | 03:25 AM
f0de's Avatar
Ham Sandwich
find a 5speed manual transmission that'll bolt to your engine of choice.. h22a comes with a trans.. you just have to modify shit to get it in
Old Nov 3, 2001 | 01:46 PM
6th Gear
will the h22a work on my 97 2.2?
Old Nov 5, 2001 | 03:19 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Yes.
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
wusty23jd
Sep 24, 2015 11:41 AM
iCrap
Sep 11, 2015 06:21 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
