Engine Replacement
Engine Replacement
Am i right in believing that if you replace the stock engine on our cars and the car is an automatic, if you put in a Japanese engine will it turn it into a 5 spd. because i keep hearing, "if you get this engine you get --hp plus the 5spd. whats this mean! please help?!?
thanks.
thanks.
engine replacement
I wasn't asking what 5spd means, i was asking if you replace your engine does it turn your automatic into a stick? because people are saying "you get the 5spd" shouldn't they already have one?
you can get a manual trans.. you need to get a manual center console for the shifter so it has room.. or just cut your center console into a big square.. and you need to hang a clutch.. its work so don't think your just going to drop a new engine in and magically have a 5spd
So am i going to have to replace the transmission and the engine or can i keep the stock transmission. Or can i just replace the transmission for a stick and put a turbo in. Does anyone know how much this will cost me for installation? Or even how much new transmissions cost if all i have to do is replace that to get the 5spd?
wusty23jd
Sep 24, 2015 11:41 AM
