DRL Problem
Old Feb 28, 2003 | 03:24 AM
1997 CL 3.0's Avatar
DRL Problem
Hi I've got a 97 3.0 and I'm having a problem with my Daytime Running lamps, it seems that the indicator on the dash is on and my DRL's are not functioning a secondary problem related to this is that my passenger side High Beam is not working, what gives? I've check the fuse and it is fine and I replaced the passenger side High Beam but to no avail. Has anyone else had this sort of problem? Initially the DRL's would kinda turn on after I drove the car for a bit but now they won't turn on at all.
Thanks.
Old Feb 28, 2003 | 04:59 AM
azn5ucka86's Avatar
the 97' 3.0's had drls', are you sure about that? cuz my 99 3.0 doesn't have them
Old Feb 28, 2003 | 07:58 AM
gjr2001's Avatar
An Official Cl Whore
Canada requires drl on all cars.
Old Feb 28, 2003 | 09:59 AM
Slooo97CL's Avatar
canadian, eh? Maybe you blew a fuse? Or a relay is shot?
Old Feb 28, 2003 | 10:08 AM
nandowong's Avatar
Work safe avatar bish :D
yup, canada has to have them. If you check on your fuse box by the driver sides feet you will see that there is a fuse for the drl, but is block off if you have an american model.
Old Feb 28, 2003 | 10:09 AM
nandowong's Avatar
1997 CL 3.0 did you check both fuse compartments? one on the engine bay and the other on the drivers feet?
Old Feb 28, 2003 | 10:31 AM
melo72's Avatar
Does that mean we could have DRL if we get a fuse and someone unblock it?
Old Feb 28, 2003 | 10:37 AM
Yea I recall I did check the fuse once and they were fine both engine and by my feet but I'll check again when I go out.
Old Feb 28, 2003 | 11:38 AM
lowboy's Avatar
it might be the wiring harness for the lights but in that case all of them shouldnt go out just the brights or the running lights not both doublecheck the fuses
Old Feb 28, 2003 | 01:29 PM
VXCL's Avatar
AWD Torque Monster
i need a DRL kit! i want to hook my highs up to it. i think the car will look nasty with the inner lights on with my parkin lights during the day. dont feel like runnin the hids all the time
Old May 27, 2004 | 08:00 PM
hougee's Avatar
kee-master
exact same problem with my car ... i used to flicker the high beam and the DRL will come on... but now it's just dead.. no workie no more... passenger side high beam is dead too
Old May 28, 2004 | 12:56 AM
hougee's Avatar
kee-master
found a website that has great info on the DRL problem.. apparently it's happening to many other hondas in Canada...
i'm gonna try to fix it this weekend
http://www.realcaraudio.com/forums/s...d/t-25406.html
Old May 28, 2004 | 02:00 AM
DanMan1464's Avatar
Autobot
i have a fuse in that spot...but i dont have DRL's
Old May 29, 2004 | 07:12 PM
Hobo's Avatar
Flap.
good question... someone who knows somethign about lights should look into the *cough* VXCL *cough*
Old May 24, 2006 | 10:07 PM
J.ENNS's Avatar
Hey, I have a 97 3.0cl and I've run in to the exact same problem with the DRL's and highbeam as discribed above, how do I fix this problem?? and the link seems to have expired.
Old Jan 30, 2008 | 04:09 PM
CRXZC's Avatar
I'm having the EXACT same problem with my 2.3... anybody know what's up??
Old Jan 30, 2008 | 04:43 PM
WolfBoy's Avatar
Flamenco Blk 3.0CL PREM
yes the DRL Modual a grey bix top of driver's feet underneath the steering column is faulty
after 10 years the solder on the DRL kit cracks and sometimes is turns on and if u hit a bump or if it gets cold it stops working ..
to fix .. either buy a new one from honda for around 200 or take the old one out of its housing .. find the solder points that are cracked and re solder and ur good as new
Old Jan 30, 2008 | 05:06 PM
Dicorp's Avatar
buy one on ebay for less than 50 bucks, guy sells them in canada. search "DRL relay"
or re solder if you know what you're doing
Old Jan 30, 2008 | 06:16 PM
Danil ACE's Avatar
Sounders FC
just unplug the DRL. who needs their lights on during the day anyways?
Besides it's probably a cheap ticket if you get caught anyways.
Old Jan 30, 2008 | 06:57 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
don't forget about insurance...
Old Jan 31, 2008 | 12:00 PM
CRXZC's Avatar
Anybody know if Honda uses a standard relay?
I have a CRX Parts car with DRL. I don't want to spend $200..
I may just unplug, hoping it will work as normal without the relay
Old Jan 31, 2008 | 01:04 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
the relays are pretty universal as far as I know, the only thing may be the wiring harnesses are different, depending on how it's wired
Old Jan 31, 2008 | 01:15 PM
jameswbl's Avatar
98 2.3 CL
check fuse if its ok you need to locate under the dash (close the steering column and behind the temp sensor) and open up the relay to solder some weak/broken solders...VERY COMMON...
Old Jan 31, 2008 | 01:41 PM
Dicorp's Avatar
what year is your CRX. the one i got for my CL was listed for 92+ hondas
Old Jan 31, 2008 | 02:46 PM
CRXZC's Avatar
92+ hondas would be easy, if they are universal..
CRX is a 91... might be the same I'll have to check
Thanks for the help guys!
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
