Damn Oil Filter...Please help
Does anyone know how to get the oil filter off our cars. The damn thing is in the most rediculous place. I bought a oil filter wrench but it's so damn tight in there, I can't get a good grip. Is there any other tools you guys can suggest? Thanks a million.
Old Timer
Originally posted by R1Performance
Pretty ghetto method, but try getting like a rubber glove, or something with a lot of grip, like a golf glove, and turn it with your hand.
this is my method ( make sure there isnt oil all over the filter as well, that ma cause a little problem
it's a pain but the filter wrench should work- take the round part and get it around the filter -don't worry about the handle until the round part is completey around the filter, then grab the handle and pull to tighten the round part and twist off the filter --it's not easy but it will work eventually
there is a different tool that work like the wrench one but with out the handle....i'm guess theres no room for you to the handle. if you can find the other tool that should do it the trick. Use Fram oil filter next time =)
A-CL Member
Word of caution if you use those Fram oil filters with the new easy-grip coating. After a while, the black stuff gets cooked and then when you get underneath and grab it, it flakes off and you get a face full of that crap. It tastes great.
I have a small oil filter wrench that barely fits - it only moves a little bit, but if you keep at it, the filter will eventually loosen up.
My special tool is my right hand. Comon guys, I'm not that big and or super strong. And I haven't really had any problems takin my oil filter off. Worse comes to worse, just put a screwdriver in there and just turn.
You Fawkin Kiddin Me!
Re: Damn Oil Filter...Please help
I'm sure the 2.3/2.2 are different than the 3.0's. The filter is closer to the right tire than the left.
ummm... then its the same!! like i said behind the RIGHT FRONT TIRE... that would be closer to the right than the left.... lol
Old Man
No, it's not the same. I believe on the 2.2 and 2.3 the oil filter is between the firewall and the engine. You would need to reach between the area with an oil filter wrench. The thing that sucks about it is that, when you do get the filter loose, the oil runs down your arm.
The best tool is the one that you can use with your 3/8 socket ratchet it looks like a cup. That is, if you haven't deformed your filter trying to get it out with plyers, screwdriver or the famous strap wrench.
Old Man
Use a grippy glove man, its cleaner, and its easier to snake your arm up there instead of trying to fish the filter w/ a tool.
i thought its like behind the motor and right in middle....if you look from above the intake manifold i think you can see it.....and the 3.0 is just hanging behind the right front wheel (great place to put a oil filter).
HOOK EM HORNS
theres no way you can get to a 2.3's oil filter from the right tire its in the middle in an odd spot (unless you got skinny arms and can slide it around the backside of the motor) jack it up,, its not 2 far from the drainplug
Moderator Alumnus
1 Post
Come on dude. He was just kidding.
IBankMouse
06-13-2020 12:53 PM
