couple of maintanance q's..help
Old Oct 9, 2001 | 01:24 PM
tangun77's Avatar
5th Gear
ok, i bought a used 97 3.0 cl and have a few problems and was wondering if anybody could help me with them...
1) sometimes i sit in the car for a couple hours with the engine off, but the radio and/or aircon on..occassionally, the lights will start to dim and the windows go REALLLY slow, then when i try to start the car, it just clicks...then when i come back to the car a few hours later, it starts perfectly fine with no delay or dimming,, do i need a new battery?
2)when it gets cold out and i havent been in the car for the while, the car often has problems starting..it seems to have enough electricity, but it just makes that high pitched sound and the engine starts maybe 5-10 seconds later, if i turn the engine off and start it again, it goes immediately..im worried that when it gets real cold, my car wont start at all, anyone have ideas??
Old Oct 9, 2001 | 01:29 PM
acura2.2vtec's Avatar
I use a condom?
To answer your first question. No you dont need a new battery, however if you continuse to let it set like that you will eventually need a new one. What your doing is running the surface charge off the battery. Eventually it wont be able to hold a charge anymore. On a side note, i didn't know you could run the AC w/o the engine running???
Your second question...hmmm does it sound like the starter is grinding or what? Also how cold is it there? Sometimes if you turn your car to the "on" position for a few seconds then crank your engine some people say it helps.
Also WELCOME TO THE BOARD AND HAVE A WONDERFUL TIME POSTING
Old Oct 9, 2001 | 01:43 PM
tangun77's Avatar
5th Gear
thanks for your response..ok the sound the car makes when it doesnt start immediately is kind of hard to describe, but its like the sound the car normal makes for a split second before the engine vrooms..its like a high pitched i guess, "electrical" sounding screech..i dont know how to explain but it sounds like the car is struggling..but thanks for your tip, ill try that and hopefully i dont get stuck in the middle of nowhere..
Old Oct 9, 2001 | 01:47 PM
I use a condom?
Originally posted by tangun77:
<STRONG>but thanks for your tip, ill try that and hopefully i dont get stuck in the middle of nowhere..</STRONG>
And if you do then you at least have roadside assistance
BTW your form chicago i see. . . well were haveing a meet there on the 28th of this month. Check out the Meet. The only thing is i think it was changed to the 28th.
[ 10-09-2001: Message edited by: acura2.2vtec ]
Old Oct 9, 2001 | 02:16 PM
1StGenCL's Avatar
958 & 991
Originally posted by acura2.2vtec:
<STRONG>On a side note, i didn't know you could run the AC w/o the engine running???
</STRONG>
You cant. You can leave it on but the cold air wont come out after a few minutes.
Why are would you sitting in your car for a couple hours w/o the engine running and the a/c on any way
Old Oct 9, 2001 | 02:43 PM
I use a condom?
Originally posted by 1StGenCL:
<STRONG>
Why are would you sitting in your car for a couple hours w/o the engine running and the a/c on any way </STRONG>
thats what i was wondering
Old Oct 9, 2001 | 03:29 PM
Nugs3's Avatar
Tangunn77 where in chicago?
Old Oct 9, 2001 | 04:27 PM
tangun77's Avatar
5th Gear
sorry, i meant the heater...i live in western suburbs by the way
Old Oct 9, 2001 | 04:53 PM
I use a condom?
<STRONG>sorry, i meant the heater...</STRONG>
I dont think you can use the heater with the engine off either...
Old Oct 9, 2001 | 04:58 PM
1StGenCL's Avatar
958 & 991
[QB]
QB]
Haha I dont think you can either. But i gotta ask again why would you sit in your car for hours w/o the engine running but the heat on.
Old Oct 9, 2001 | 05:39 PM
tangun77's Avatar
5th Gear
well, u see, sometimes my brain doesnt function properly,,,i was wondering why the heater wasnt working well..
Old Oct 9, 2001 | 06:36 PM
I use a condom?
<STRONG>well, u see, sometimes my brain doesnt function properly,,,i was wondering why the heater wasnt working well..</STRONG>
we just like n giving newbies shit. It's nothing personal man
Old Oct 9, 2001 | 08:21 PM
Atl-CL's Avatar
Don't hate the PLAYA
lay off the crack pipe.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
spudweb
May 22, 2016 02:39 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
hashbrown
Sep 29, 2015 12:13 PM
AcuraKidd
Sep 25, 2015 11:18 PM
