Checking in
Old Oct 14, 2009 | 05:41 PM
LLWesMan's Avatar
Ahhhhhhhh
Checking in
Hey fellas, hope all is well.
About to do a little maintenence on the car and just wanted to confirm a few things with the experts.
Gotta replace the corner bulbs next to the headlights. Figured I'd go with hyperwhites instead of the stock yellows to better match the projectors. I'd like to do the top (A) and bottom (B)
Now the noob guide lists these: "Front corners | 168/194" as the part numbers - does anyone have recommendations on a particular brand? Ebay or online store link would be greatly appreciated.
My second question regards the AEM V2 intake filter. Mine is black with usage and needs to be either cleaned or replaced. How hard is it to do the cleaning using the K+N kit? It looks like the kit is about $25 - http://www.autoanything.com/air-filt...A1993A0A0.aspx
Would it just be smarter to replace the filter with a new AEM? I can't even find the accord 94-94 model on ebay anymore. Anyone know of a place - link?
Thanks for reading this essay
Old Oct 14, 2009 | 06:08 PM
DaInFaMMuS1's Avatar
idk about the bulbs, but the K&N kit works pretty well and is easy to use. I've cleaned 3 filters with it already
Old Oct 14, 2009 | 06:45 PM
DjXtC34's Avatar
bulb i bought was 194 and i went with the led white. www.superbrightleds.com web site
Old Oct 14, 2009 | 11:04 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
K&N kit works wonders for cleaning filters
Bulbs are 194/168 wedge bulbs, I recommend 4 LED white bulbs, from superbrightleds.com or autolumination.com
Old Oct 15, 2009 | 12:16 AM
LLWesMan's Avatar
Ahhhhhhhh
So if I were to go with the top bulbs on this page: WLED Miniature Wedge Base bulbs
T3-1/4 (#194/168)
http://superbrightleds.com/mini-wedge.html
would I need anything else? Like the sockets? Or will they plug and play with the current stock setup?
Planning on going with the cool white X6 model to match the projos - will the X6's work?
Thanks!
Old Oct 15, 2009 | 09:20 AM
South Jersey CL's Avatar
i have the WLED xHP5 wedge based bulbs in my car. theyre bright as fuck. and they just plug right in to the existing socket.
Old Oct 15, 2009 | 03:29 PM
(Mid-Atlantic)
Yep you shouldn't need any special sockets or anything
Old Oct 15, 2009 | 08:29 PM
Project_CLean's Avatar
MMkay.
everyonez right about the bulbs..as far as the recharge kit from k&n its easy. but your cars going to be out of work for a day. after the cleaning you have to wait for the filter to dry completely then apply the oil. if i were you. i would just get another filter and keep the one you have now as extra?
Old Oct 15, 2009 | 10:13 PM
Blazin Si's Avatar
The K&N kit works great. A cheaper alternative is to go to an atv/motorcycle dealership and purchase a filter cleaning kit from them. You'll probably find them in the racing section. They used to be under $10 and are the same thing as the K&N kit.
Old Oct 16, 2009 | 04:36 AM
LLWesMan's Avatar
Ahhhhhhhh
Ordered the "cool white X6" model. I'll take pics once they come in. Thanks for all your help!
Old Oct 30, 2009 | 07:00 PM
LLWesMan's Avatar
Ahhhhhhhh
My door lock actuator appears to be dying in my passenger side. How hard/expensive a fix is this?
Old Oct 30, 2009 | 09:06 PM
crx_91si's Avatar
V-DUB TECH
you'll need #6 in the picture i believe
http://www.acuraautomotiveparts.org
72110-SY8-A01
LOCK ASSY., R. FR. DOOR POWER
89.33
but...you might be able to just get away with just #10
72115-SY8-A01
ACTUATOR ASSY., R. FR. DOOR LOCK
48.35
and then just pop the door panel off and it's all right there. shouldn't take more then a couple hours if you got tools and half a brain
mike
Old Oct 31, 2009 | 12:02 PM
LLWesMan's Avatar
Ahhhhhhhh
72110-SY8-A01
89.33
72115-SY8-A01
48.35
mike
Any way to figure out if I need more then just #10? I don't want to pop open my door and realize I needed a new part. Is there a guide to removing your door panel on here?
Old Nov 2, 2009 | 01:42 PM
LLWesMan's Avatar
Ahhhhhhhh
Up
Old Nov 2, 2009 | 01:49 PM
(Mid-Atlantic)
Door panel is easy, it's been posted on here a ton, first remove the mirror cover, just pops right out. Then on the door panel theres 2 screws, one in the base of the handle and one in the top part of the handle going straight in. Remove those 2 screws, then start popping the clips on the door panel from the outside in, once you have popped a few, you can reach in and remove the wire for the door light, then you have to pop the clips the rest of the way, and then remove the wires for the window switch, then it's just a matter of wiggling the panel up and out, very straight forward.
Also, when you put the panel back on, make sure your window is down
Mike Pilipenko
Mar 26, 2024 09:21 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
hrothgar02
Sep 28, 2015 11:08 AM
mars
Sep 28, 2015 11:03 AM
