Check engine light Bulb?
Old Oct 8, 2005 | 08:48 PM
DJBOMBERMAN's Avatar
Red face Check engine light Bulb?
'97 Acura CL 3.0
Apparently the Check Engine light burned out and it needs to be replaced to pass emissions. The Acura Dealership near me informed me that they did not know which bulb needs to be replaced for this. Had the part guy ask a master tech. So I thought I would ask if any of you have replaced this? Let me tell the story....
In order to pass emissions here in Arizona I had to have the EGR port drilled out and the kit placed on it, I had to pay all of this out of pocket something like $350! They wouldn't even work with me on the price, guess it's the bitch of living in Scottsdale huh? I have 212K on my car. Now I am informed that the Catalytic convertor is failing.
Here are the questions I have...
How do I remove the speedometer cluster to change the Check Engine bulb? Does anyone know what bulb I need to replace ?
Can I get a Catalytic convertor for my 97 CL 3.0? Factory one is $650!
I've checked online at Checker autoparts and they have one for $89.
Thanks for all your help in advance, I threw alot of issues and questions out there at once.
Old Oct 8, 2005 | 08:53 PM
ajtcl's Avatar
Peace, Love & Acura
Go to the DYI section and look for blue bulb conversion or something like that. There are some rather detailed explanations there on how to remove the gage bezzel and cluster. As for the CAT, you should be able to use the same one as that of a 98-00' Accord EX.
Good luck and watch out for some expected
Old Oct 9, 2005 | 02:33 AM
Outlaw's Avatar
CL smashin
It's a size #74 bulb. You can find it at http://www.autolumination.com/ or that other link that Musulsa put in the DIY for the LED gauge conversion.
Old Oct 9, 2005 | 03:06 AM
wilp99's Avatar
swap it for a bulb you dont need. just to pass the inspection.
Old Oct 10, 2005 | 01:31 AM
Thanks for the help guys. I did a search I must of spelled something wrong. I found how to take the guages out.....
Does it matter if I use incandescent or focused LED?
Here is a pic of the gauge cluster, I placed a red arrow by where the check light engine is in the cluster...
Which bulb is it in the pic? I am assuming it is # 3 in the diagram? The only thing is that the Check engine light burned out and none of the other lights are out. Has anyone ever changed one before? Everyone at the Acura dealership said it is extremely rare when this happens, it should really never happen. Is there something else that could be wrong with it as well? Thanks for your help....
Old Oct 20, 2005 | 08:00 PM
Cool
The guide to remove the Guage Cluster was awesome. I wish I would have had my digital camera to add to the changing of the Check engine light as well.
Once I had the Guage cluster off I had to remove the back, by unscrewing the 2 screws holding on the white backing.
Then, once I had that piece off, I had to remove the long metal screws holding the circuit board onto the cluster.
Once that was off, there was a whole set of lights that you turn and remove. They are small and similar to the the ones you remove to light up the display. I purchased the bulb and replaced everything and the Check engine light now comes on.
If anyone would like to know the process let me know. I did it without any problems. Now, I just need to know how to clear the memory so the check engine light will shut off. Thanks everyone for helping me out with were to go! You guys are a great community!
Old Oct 20, 2005 | 10:42 PM
wilp99's Avatar
go to autozone they can do it for free. or you can disconnect your battery for 15-20 minutes.
Old Oct 20, 2005 | 10:51 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Look out for all the scottsdale snobs...I lived in phx for 2 years. That was 2 years too long! lol...
Old Oct 21, 2005 | 01:57 AM
Smile
That will clear the OBC if I disconnect the battery? It clears out everything that was stored in it?
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
