Check Engine Light On
Old Jul 11, 2005 | 01:53 AM
clmdcn's Avatar
9th Gear
Question Check Engine Light On
MY CHECK ENGINE LIGHT IS ON SO I WENT TO GET IT CHECK OUT AND THEY SAID THAT THE EGR VALVE IS BAD SO I GOT A NEW EGR VALVE AND CHANGED IT BUT ITS STILL ON. DO I HAVE TO GET THE ECU RESET? IF YES CAN I DO IT MYSELF? AND HOW? BY THE WAY I GOT A 3.0CL. SOMEONE HELP PLEASE!!!!!!!!!!!!
Old Jul 11, 2005 | 02:07 PM
teh CL's Avatar
first of all, turn off the caps lock
and yes you do have to reset it..
Old Jul 11, 2005 | 02:21 PM
ajtcl's Avatar
Peace, Love & Acura
Dis connect your battery for 30 seconds, or if you want to keep you radio presets... Dis connect the secondary clock fuse for 30 seconds. That should clear it. There is also a service plug that you can jump two of the pins, but I don't remember the pin numbers to jumper.
Old Jul 11, 2005 | 04:15 PM
wilp99's Avatar
if you have a 3.0 you need to clean out the egr paths in your intake manifold.. the ONLY way to do it is remove the intake manifold. its actually not hard, but if you reset the light it will come back on within the week.
Old Jul 11, 2005 | 05:53 PM
Smalls's Avatar
Insert Sarcasm Here
Old Jul 12, 2005 | 04:20 AM
clmdcn's Avatar
9th Gear
Sorry
clmdcn's Avatar
9th Gear
Thanks guys
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
