cars overheating...
Old Jan 12, 2010 | 12:54 AM
MoSp33d's Avatar
N00berator
cars overheating...
hey guys hope all is well....the other day i was driving to autozone to pick up something and as i put the car to park the temp. needle shoots up above mid line. i step outside and i see coolant on the ground...i take it home asap and i checked out the radiator and i didnt see any leak...however, the coolant tank was overflowing with coolant...and i havent poured any coolant for the past yr...now my question is, is this a bad water pump or a thermosat? cuz recently i have been hearing some whining noise from the alternator area...im not sure what it is...any input????/
Old Jan 12, 2010 | 08:22 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
sounds like the thermostat, they go bad on our CL's all the time, but the belt whining could be indicitive of a pulley problem with the water pump, I would check the thermostat first though
Old Jan 25, 2010 | 12:55 PM
JRoc99Cl's Avatar
Sounds like a stuck thermostat. When was the last time it was changed? Was the whining there before it overheated?
Old Jan 25, 2010 | 09:56 PM
1slo23's Avatar
Runs on Dunkin
x2, same thing (minus the leak) happened with my old CL
Old Jan 25, 2010 | 10:09 PM
asianspec's Avatar
Check your hoses while you are at it.
Old Feb 1, 2010 | 09:05 PM
hwdp420pl's Avatar
DJ MSR NRG!!
same problem happend to me i changed the thermo and it still was the same then i found out it was the stupid radiator cap
Old Feb 2, 2010 | 02:07 AM
MoSp33d's Avatar
N00berator
hey guys sorry i didnt post bak on this....it was actually my temp. sensor
Old Feb 2, 2010 | 01:22 PM
Myxomatosis's Avatar
on this same topic. When my radiator went last week, it was almost empty, I saw the leaking fluid filled it up and havent had a problem since. I figure it just plugged itself, but I am still somehow confused.
Old Feb 10, 2010 | 04:52 PM
khmerpride's Avatar
Same thing happens with my car, something is wrong with the fan or a sensor somewhere, even the thermostat is probably gone too. It'll overheat if I drive a long time and stop on the highway, I just turn up my heat for a temp fix right now until spring.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
