camber kit
Old Oct 18, 2002 | 06:38 PM
Yajarobi420's Avatar
camber kit
which camber kit is better to get the 3 degrees or 1.75? and which is better the rubber bushings or urethane?
Old Oct 18, 2002 | 07:00 PM
suXor's Avatar
Still trolling
The camber kit you need depends on how far out it is. You need to have your camber measured first.
Lastly, get new adjustable ball joints, not the bushings one. THe one you are looking at has been known to hit the upper inner fender well causing noise and poor ride. You have to beat it or cut it out to make room. The ball joints are only about 50 bucks more.
Old Oct 18, 2002 | 08:53 PM
ATLcl98's Avatar
Atl/Mia reppin'
I agree with chris...get ones with adj. ball joints. If you end up not, get ones with Urethane bushings. He's right, find out how far out your camber is before you buy the kit. From what I know, I'd recommend Specialty Products for a camber kit. Next week when I do my alignment I'll find out if I'll need anything...
Old Oct 18, 2002 | 09:56 PM
what do u think of the comptech camber kit?
Old Oct 19, 2002 | 01:31 AM
MaCe's Avatar
fellow MASShole
never heard any review on the comptech one .. i got the ingalls corrects up to 3 ... and works great my front driverside wheel was off 2.73 and its now back to stock regulations i forget what i got all the paper work if u want numbers ...
Old Oct 19, 2002 | 08:31 PM
im confused. so i need an adjustable camber kit and a new ball joint? or does the adj. ball joint fix the camber and that is all i need?
Old Oct 20, 2002 | 04:59 PM
MaCe's Avatar
fellow MASShole
ball joint?? where u gettin this ball joint info from ?? all camber kits are adjustable just some correct more than others .... if ur talkin about the rear arm that some kits offer dont get it u dont need it ... with my 2in drop my rears were only off .5 and .75 witch the ingalls kit corrected fine
Old Oct 20, 2002 | 06:00 PM
suXor's Avatar
Still trolling
These are the kind people have problems with (not necessarily Ingalls though):
http://www.ingallseng.com/parts/3570.html
These are the ball joints that allow for more correction, and are a better solution:
I believe only Progress Technology and Specialty Products make the ball joint type for our cars. The rest are the pivot style busings for the upper control arm.
Rear camber can be corrected with washers most of the time. Mine was only a 1.5" drop in the rear, so washers will get it back.
Old Oct 20, 2002 | 06:32 PM
MaCe's Avatar
fellow MASShole
ohh ... never seen those before ..
Old Oct 21, 2002 | 03:11 AM
acuradan69's Avatar
I have probs with rubbing the upper inner fender with my eibach pro kit/ koni yellow adjustable(middle perch) combo with a sprint suspension camber kit...
Old Oct 21, 2002 | 07:55 AM
suXor's Avatar
Still trolling
What is rubbing? THe tire or the hardware? You could switch to the ball joint to help...
Old Oct 21, 2002 | 07:32 PM
i am going to go with the ball joints. thanks for all the help.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
