Bushing changes!?
Old Jan 21, 2004 | 10:29 PM
CLpower's Avatar
teh Senior Instigator
Bushing changes!?
Anyone done much switching out of bushings for stronger? I'm currently debating doing the full Energy Suspension bushing kit. I currently have the sway bar and end link bushings but my end link bushings stripped on one side and need to be replaced so I was just thinking about doing the whole thing.
Old Jan 21, 2004 | 10:32 PM
CLpower's Avatar
here is the info
1994-97 HYPER-FLEX SYSTEM Complete Master Bushing Set 16.18107
master sets include: front control arm bushings, front strut rod bushings, front shock bushings, front coil spring isolators, front end links, ball joint boots and tie rod end boots.
CLpower's Avatar
I don't know a price on it though
Old Jan 21, 2004 | 10:34 PM
CLpower's Avatar
this place has it for 109.99
I can probably get it cheaper through a distributer out here though.
Old Jan 21, 2004 | 10:50 PM
r3mix3r's Avatar
Would this get rid of my very bad squeak? The shop told me one of my bushings was fuked...
Old Jan 21, 2004 | 10:56 PM
CLpower's Avatar
yep yep, but it'd be easier for you to find out which bushing and just change those, would dave you cash. Cheapest I found on the net was ebay for 89.00 and 8 shipped. Most sets of bushings are like 10-20$
Old Jan 22, 2004 | 12:03 AM
VXCL's Avatar
AWD Torque Monster
i have the full kit. decided against it. i just used the upper shock bushings and coilspring isolater. aso used the sway bar endlinks. my ride got firmer. i dont want it any stiffer so i just said screw the rest
Old Jan 22, 2004 | 12:06 AM
ATLcl98's Avatar
Atl/Mia reppin'
i have a set of poly bushings, but i don't know what brand they are. The shop originally installing my shocks ruined the rubber bushings so they replaced them w/ poly ones for free. I guess I should be excited
Old Jan 22, 2004 | 09:01 AM
CLpower's Avatar
did the shock bushing make a significant difference? Can you explaing the coilspring isolator Is it just a little wrap around?
Old Jan 22, 2004 | 11:25 AM
VXCL's Avatar
AWD Torque Monster
the coilspring isolator is the pad on top of the spring that sitsin the oem upper mount. the upper shock bushings made the ride firmer and the shocks reacted slightly faster. one of them shredded on me some how so now im back on oem rubber.
Old Jan 22, 2004 | 03:11 PM
Sacramento CL's Avatar
A-CL Member
My neighbor who sells auto parts warned me that poly bushings squeak real bad.
Old Jan 22, 2004 | 03:14 PM
melo72's Avatar
I need to change my bushings also. My stock ones are shot since I didn't change them when dropping the car. My rear passenger side squeaks like a bitch!
Anyway, maybe we can get a groupbuy going for the ones from Energy Suspension....
Old Jan 22, 2004 | 03:49 PM
CLPowersWife's Avatar
What do bushings do?
Old Jan 22, 2004 | 06:38 PM
VXCL's Avatar
AWD Torque Monster
honestly brand new oem honda bushing fitment, quality, and design are second to none. i got brand new honda lower bushings in all four shoucks.
Old Jan 23, 2004 | 11:47 AM
melo72's Avatar
So VXCL, you think the Honda bushings will be better than poly even on a lowered car?
Old Jan 23, 2004 | 01:27 PM
A-CL Member
They're kinda like bearings for your suspension. If you've ever changed a shock, you can see the rubber bushings in the top & bottom mounting points. The factory uses rubber bushings where all of the suspension parts are bolted together. Rubber is soft and wears out. As the rubber gets old, steering and handling get sloppy because of the extra play. Polyurethane his harder. The negatives to poly bushings is that they ride a little harder and can squeak. On the plus side, steering response and handling is improved. There's more here: http://www.energysuspension.com/
Old Jan 23, 2004 | 03:56 PM
VXCL's Avatar
AWD Torque Monster
well on the lower shock mounts yes. ull notice nothing diff just firmer ride. i think sway bushings are prob the best thing to change to poly. even new honda bushings make a big diff if urs are dry rotted and worn. and again the fitment and overall design of the energy suspension bushings were nothin like honda's.
unless u track ur car i dont see you noticing anything but an unwanted firmer ride where u feel everything in the steering wheel.
i was happy with the upper bushings, coil spring pad, and new swaybar endlinks, and new honda lower bushings
Jul 16, 2017 07:33 AM
Brandle34
Sep 23, 2015 07:20 PM
milehightypes
Sep 10, 2015 12:07 PM
gqdabien
Sep 8, 2015 11:41 PM
