Bushing changes!?
teh Senior Instigator
Bushing changes!?
Anyone done much switching out of bushings for stronger? I'm currently debating doing the full Energy Suspension bushing kit. I currently have the sway bar and end link bushings but my end link bushings stripped on one side and need to be replaced so I was just thinking about doing the whole thing.
here is the info
1994-97 HYPER-FLEX SYSTEM Complete Master Bushing Set 16.18107
master sets include: front control arm bushings, front strut rod bushings, front shock bushings, front coil spring isolators, front end links, ball joint boots and tie rod end boots.
yep yep, but it'd be easier for you to find out which bushing and just change those, would dave you cash. Cheapest I found on the net was ebay for 89.00 and 8 shipped. Most sets of bushings are like 10-20$
i have the full kit. decided against it. i just used the upper shock bushings and coilspring isolater. aso used the sway bar endlinks. my ride got firmer. i dont want it any stiffer so i just said screw the rest
i have a set of poly bushings, but i don't know what brand they are. The shop originally installing my shocks ruined the rubber bushings so they replaced them w/ poly ones for free. I guess I should be excited
did the shock bushing make a significant difference? Can you explaing the coilspring isolator Is it just a little wrap around?
I need to change my bushings also. My stock ones are shot since I didn't change them when dropping the car. My rear passenger side squeaks like a bitch!
Anyway, maybe we can get a groupbuy going for the ones from Energy Suspension....
Originally posted by Cr.ash79
What do bushings do?
Originally posted by melo72
So VXCL, you think the Honda bushings will be better than poly even on a lowered car?
unless u track ur car i dont see you noticing anything but an unwanted firmer ride where u feel everything in the steering wheel.
i was happy with the upper bushings, coil spring pad, and new swaybar endlinks, and new honda lower bushings
