blown lights
blown lights
hey guys,
I was switching my corner lights last night to some blue LEDs, and everything was fine until I closed my hood and the corner lights, back tail lights and in dash light all shut off at once. I was wondering if anyone knows the problem.
PS ...I already checked all the fuses there fine
Did you check the underhood fuses AND the cabin fuse boxes? Sounds like you blew a fuse. Least I hope you did, cuz otherwise it sounds like the relay
happened to me as well, it was a fuse in my case, either that or all your wiring just happend to burn out all at once, but thats what the fuses are for
its not anything with the LEDs because ive got amber LEDs in all my corners and they work just fine
Originally Posted by ZeroCL
Bump, whered you get that fuse from? how much? thanks.
i had the same problem only it blows the fuse every time i turn the lights on. i once smelled burning so im thinking that the switch is f***d.... i hope so anyways cus i bought a new one and its $70 to install. btw does anyone know if the 97-01 prelude light switch/turn signal switch is compatible with our cars? pretty sure it is.......
I called Chris, told me there were spares in the inside fuse box. got the problem solved. thanks guys. i guess my LED's didnt have resistors like my old ones did.
so you called me after the thread?
wow I thought you called me first, god damn never thought explaining a fuse would take 15 mins
mada51589
Jan 9, 2025 04:40 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
