Best way to kill sound
Im going to redo my trunk, mainly because i fried one of my subs the other day.
I want to dynamat the trunk, what should i use? is dynamat the best? i see stuff on ebay, brown bread, deadliner, and dynamat
are any of these better than the other?
how much do i need to do the floor both sides the lid and the back speaker deck?
and damn no one on ebay has the kicker l7's that are not refurbs
they are waiting for the new shiny ones to come out
any tips on how to go about this would be much appreiciated
THANKS
THANKS
TEAM BLUR So. CAL
Originally posted by dennis
Dynamat extreme-
requires no heating at all, unlike brown bread...
requires only one layer, unlike brown bread which suggests 2 for optimum performance...
Odor free...
Better damping capability and damping range...
Higher effective ranges in the heat and cold.
Odor free...
-S namyaC-
How much weight are you really gonna save? If you are concerned about 20lbs, you shouldn't have a bumping stereo in your car anyway.
Dynamat Extreme is my pick. Get a good roller.
TEAM BLUR So. CAL
http://www.b-quiet.com/compare.html
and you wrong about the acoustic loss factor in heat and cold. there's not much of a difference. it is also easier for brown break to form to shapes because it has to be heated. it will form to dips, curves, and everything else. it is also a cleaner install. once you put dynamat on that's it. with brown bread you can place it perfectly before you heat it so that it is exactly where you want. price is also something you should look at: brown bread is 2.17 per square foot, as where dynamat is 5.42 a square foot. and you can use multiple layers but one layer will be the equvialent of one layer of dynamat. in fact at room temp(86degrees), brown bread dampens better than dynamat extreme.
check out this install in honda tuning
http://www.b-quiet.com/hondatuning.pdf
The movement has started
I'll stick with spray insulation lightweight and easy to apply. You can also try cork sheets leightweight and completely kills sound. I'd say who cares about the weight if you got a bad ass stereo you should either have a bad ass engine to go along with it, or not care about speed at all.
112K and on 1st tranny!
Originally posted by TeamBlurryCL
[B in fact at room temp(86degrees), brown bread dampens better than dynamat extreme.
[/B]
[/B]
HOLY SHIT! that's room temp? I think i'd be sweating bullets at that temp!
But what i do have are some bad ass rattles, like the back deck and what not.
Im just tryin to make the music sound cleaner, i dont care about weight either
whats this coark board you speak of ???
thanks
1999 CL3.0
i was in dallas and i got this guys business card
he messes with foam, hes based in the new england area
he said that he had something for our car,
ill post later , i m going car shopping
1999 CL3.0
cant find the business card..
i think the name of the company was Bosal Foam.
I remember the man saying that we can use mattress foam.
the kind with the ////// or the ~~~~ in it ...
i would look kinda ghetto. maybe if carpet was put on top it'd be
aiight.. o well.
the 04 audi A8L is sick i got quoted 6,000 down 1,100/mo
aiight.. o well.
mlody
12-04-2019 02:11 PM
