ABS light
Old Dec 15, 2004 | 08:34 PM
ShibbyDevil's Avatar
Doom dee doooooom
ABS light
Hey all... my abs light started coming on every once in a while a couple days ago. It has gotten really cold out and I dont know if that is related. Any ideas? Where do I start trouble shooting? Thanks
Ryan
Old Dec 21, 2004 | 02:36 PM
Hitman's Avatar
Can you let me know what you find out, mine has done the same thing.
Old Dec 21, 2004 | 02:46 PM
sumdumguy's Avatar
a jawful a somethin awful
does it stay on while you drive? Do you get a "grinding" noise?
Old Dec 21, 2004 | 03:11 PM
Doom dee doooooom
No I dont have any noises. The light is just on. If I turn off the car it is off and back on it then comes on the same amount of time that it takes when I first start the car.
Ryan
Old Dec 21, 2004 | 03:21 PM
sumdumguy's Avatar
there are different sensors on each wheel. could be one of those. if one of your brakes isn't sending fluid back to the res. that could be it. you could need new pads....just so you know the ABS stops working when the light comes on. even if it's something small.
Old Dec 21, 2004 | 03:22 PM
Hitman's Avatar
I called the dealer and they said each wheel has a sensor for the abs and it can be one of them...that aside, I needed new rotors/pads and a caliper. So none of these things is a remedy
The light is still on.
Old Dec 21, 2004 | 03:30 PM
Doom dee doooooom
is there a way to check the codes or something. I have done it on my GMs but I dunno about hondas. Thanks.
Ryan
Old Dec 21, 2004 | 03:32 PM
sumdumguy's Avatar
Ryan
if you take out the ashtray there is a plug in there. take it to pepboys or one of those places that hook up the machine for free.
Old Dec 21, 2004 | 06:15 PM
shineynitelite's Avatar
NAWWWWSSSSSS
i think that its kinda normal for it to come on cuz i have read about this like 50 times.. someone said that it goes on because it is cold the fluid hasnt expanded and the car thinks it low.. i will believe that guy i'm too lazy to hook up my car to a sensor at work
Old Jan 12, 2005 | 06:43 AM
Hitman's Avatar
And the Answer is....
Well at least in my case, it turns out to be a "Speed sensor, linked to the ABS computer". The ABS sensor is at each wheel, my left rear one is toasted. No big deal, it just means no ABS when the light is on. I talked to the Dealer in Halifax, it's $217 for the sensor and they say 40 minutes to put it in.
Seems like a rip off to me...
Old Jan 12, 2005 | 10:47 PM
WayFastWhitey's Avatar
you dont have anything to scan, you cant take it to advance or whoever does those free "diagnostic check" those are for check engine lights only, not the abs light
Old Jan 12, 2005 | 10:51 PM
Smalls's Avatar
Insert Sarcasm Here
the abs light would come on in my 3rd gen maxima, and the common problem was a speed sensor. that could very well be it.
Old Jan 13, 2005 | 02:14 AM
wilp99's Avatar
http://home.insightbb.com/~niedejb/
go to resources... it tells u how to pull ur own codes and what they are. scroll down for the abs codes. good luck. oh yea wil is 1 cool ass mutherfucker. that is all.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
