97 Prelude engine?
Old Jul 18, 2001 | 12:08 AM
BLUE2.2VTEC's Avatar
97 Prelude engine?
Is it a direct swap or is there some customizing? So I would have to get the ecu and the tranny,right? Will the ecu just plug right in? I have a friend who works in a salvage yard who said he can get me a really good price if I ever thought about doing the swap! If I did I could go ahead and beef the bitch up while its out and gets some real horsepower under the hood!!!!
Old Jul 18, 2001 | 01:20 AM
f0de's Avatar
Ham Sandwich
my engines on order.. and i have no clue whats involved in the swap.. i've heard you need new axels.. but the stock tranny will bolt right onto it.. most engines come with trannys and the h22a trannys a bit better then ours..
Old Jul 18, 2001 | 03:48 AM
R1Performance's Avatar
Power of Dreams
H22A swap would probably need, ecu, engine, wiring harness, and axles as basic parts for the swap. Preferably you'd also probably want the transmission and shift linkage from a Prelude as well, most likely the h22a engine and the Accord transmission are not properly suited performance wise to one another.
Old Jul 18, 2001 | 04:07 AM
VXCL's Avatar
AWD Torque Monster
r1 is right on. also i hear it is also a good idea to get some new engine mounts, but they are expensive. im not sure if they come with the engine. i doubt it.
Old Jul 19, 2001 | 01:33 PM
Adrienne
Guest
Posts: n/a
Originally posted by R1Performance:
<STRONG>H22A swap would probably need, ecu, engine, wiring harness, and axles as basic parts for the swap. Preferably you'd also probably want the transmission and shift linkage from a Prelude as well, most likely the h22a engine and the Accord transmission are not properly suited performance wise to one another.</STRONG>
Hmm... wonder who that is?
Old Jul 19, 2001 | 04:06 PM
Power of Dreams
Its your imagination. I wasn't really here.
Old Jul 24, 2001 | 01:25 PM
chiggacl68's Avatar
speed freak
well im not sure...but this one place i know in my area...i was thinking of buying it...its a japanese prelude engine...u guys know the specs on it...? someone told me it should give 210 hp at the wheels not engine...its like it comes with the engine tranny clutch and ecu for about 2300 for manual...the 1600 is auto ...but of course im getting stick....but lemme know wat u guys think...im thinkin of it
Old Jul 24, 2001 | 04:11 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Originally posted by chiggacl68:
<STRONG>well im not sure...but this one place i know in my area...i was thinking of buying it...its a japanese prelude engine...u guys know the specs on it...? someone told me it should give 210 hp at the wheels not engine...its like it comes with the engine tranny clutch and ecu for about 2300 for manual...the 1600 is auto ...but of course im getting stick....but lemme know wat u guys think...im thinkin of it </STRONG>
Yeah...210 at the wheel.. My CL stock doesn't make that much at the wheel.
Find some engine mounts too...if you're swapping, you mine as well get polyurethane race mounts..and billet axles too. A Japan Spec VTEC Prelude made 210~215 at the crank. But this could be because of a freer flowing exhaust and no cat, not to mention the leaded gas they use.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
