Where is the speed sensor signal on a 2005 mdx installing eclipse avn 5510 navigation
HI EVERYONE IAM NEW HERE JUST BROUGHT MY 2005 MDX AND I LOVE IT BUT IT DOESNT HAVE FACTORY NAVI AND IAM GOING TO INSTALL MY ECLIPSE AVN 5510 DOUBLE DIN UNIT AND I NEED TO KNOW WHERE IS THE SPEEDSENSOR SIGNAL WIRE AND WHAT COLOR AND LOCATION.I ALREADY HAVE THE WIRE HARNESS AND THE RADIO DASH KIT
THANKS IN ADVANCE
THANKS IN ADVANCE
Moderator Alumnus
Welcome to the forums. The speed sensor signal wire, also knows as the VSS wire can be found under the passenger side front seat. Is a blue/white wire that should be coming out of a plug under that seat.
If you cant pull it from there look to the right of the gas pedal. Same blue/white wire.. Should be there.
Moderator Alumnus
This also might help if you want to pull it from behind the gauge cluster.
Moderator Alumnus
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
