Trailer Brake Controller
Old Sep 11, 2008 | 10:39 PM
yellowjeep79's Avatar
4th Gear
Anyone have any idea where to plug in a trailer brake controller on the '07 - '08 MDX? Dealer doesn't know.
Old Sep 12, 2008 | 08:05 AM
FiftyFive's Avatar
Moderator Alumnus
Look over this, see if this helps at all.
https://hondacuraworld.hostasaurus.c...ailerhitch.pdf
Old Sep 12, 2008 | 08:31 AM
Ikko's Avatar
So pathetic!
4th Gear
Thanks a bunch for the instructions, they will certainly be useful when installing the wiring, but they still don't show where to plug in the controller. The next to last page has a a picture of the pigtail (subharness) that needs to be spliced on to the controller, but doesn't tell me where to stick it! My Ford F 150 has a plug right under the steering wheel, but I can't find anything similar on the Acura. The only open jack I see is for the OBD II
Once again, thanks for the info
Old Sep 12, 2008 | 08:34 AM
4th Gear
IKKO,
I guess not many people tow something heavy with an Acura. This might be one of those "You might be a Redneck if..." introductions.
Old Sep 12, 2008 | 08:42 AM
FiftyFive's Avatar
Moderator Alumnus
^^ maybe..
I'm surprised the Acura dealer doesn't know.
Old Sep 22, 2008 | 05:15 PM
Fastnuf's Avatar
The electric trailer brake controller plug is attached to the underside of the black panel that is under the steering column in the driver's side footwell.
Old Sep 27, 2008 | 08:08 AM
4th Gear
Hey! There it is!
Thanks for the pics. I'm installing the Acura factory wirirng and a Valley hitch this a.m.
Bob
Old Oct 31, 2008 | 08:15 AM
moford's Avatar
Where did you mount your controller?
Old Jun 17, 2009 | 01:54 AM
whip66it's Avatar
Question Brake controller
Hi, installed all up to brake controller harness....thanks for the pics!! I assume the four wires then plug into any aftermarket controller?? If so, why does etrailer.com list all their brake controllers "not for use with OEM Acura wiring harness"??? Did anyone use a product they would recommend? HELP Please! Trying to go camping on weekend!
Old Jul 25, 2009 | 12:22 PM
frenchnew's Avatar
I use the Tekonsha P3 along with the Acura Factory Harness and Hidden Hitch 87474 on my 2007 MDX without any problem.
Best regards from Montreal
Old May 25, 2010 | 12:53 PM
SensEast's Avatar
Hey frenchnew, how did you pick up the power and brake controller signal for your 7 way to run your brakes? My installer says he can't see where he gets these 2 wires and only installed a flat 4 for me? Any help would be appreciated guys. Thanks
Old May 25, 2010 | 01:05 PM
Fastnuf's Avatar
He bought and used the OEM trailer wiring harness which plugs into the MDX chassis wiring harness. (plug & play) The OEM wiring harness comes with a brake controller 4 wire pigtail that plugs right into the connector under the dash (see my post aobve with the pictrue of where under the dash the plug is hidden) This pigtail provides all the wiring needed to run the controller/brakes.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
